Home > Beginners Tech > Centre Main Straps
Chalkie
Member #: 9764
Northamptonshire.
Properly the most stupid question ill ever ask on here
what is the point in centre main straps?
http://www.minisport.com/mini-spare-parts/info_CMS1O.html
this to me makes no sence at all
but this one dose
http://www.med-engineering.co.uk/catalogue...-bolt-main-only
as you drill and tap 2 more holes?
anyone care to explain to me please? :( feel so stupid for asking.
Thanks
Stephen
jamie@thefatgarage
Member #: 9345
Sheffield
To condense many pages to a short answer: For mega rpm engines they might be helpful, but not everyone can agree. For turbo and relatively low rpm engines they are pointless. The problem is they have become, almost by myth, part of the standard specification for engines.
For every well read and highly qualified expert that recommends them, there are equally qualified experts that say don't bother.
Good luck getting a better answer. Mine doesn't have one.
edit:spelling
Edited by jamie@thefatgarage on 24th Jun, 2012.
Chalkie
Member #: 9764
Northamptonshire.
Right okay :) turbo's don't normally rev over 6500 do they?
They generally don't need to to produce good power, but it depends on the Turbo used & cam etc
Craigie-B
Member #: 9468
Wootton Bassett
Thank you as I was puzzling myself if I made the right decision in leaving off a center main strap - I cant really see it being an issue for myself now
Just get some decent bolts & hardened washers for the main caps, job done.
Chalkie
Member #: 9764
Northamptonshire.
Haha now I see the Hardened washers alot some people say yes some people say no?
I'm on your site at the moment phil having a read through as I'm gonna build a 998 turbo :)
would bolts or studs and nuts be better for mains?
I would always use the bolts with the hardened washers. There's no way you should be torqueing a bolt head directly against the main cap.
Chalkie
Member #: 9764
Northamptonshire.
Okay Ill take that down into account thanks Phil :) what bolts be best to use?
Setup im thinking of is
998 standard dished pistons
standard rods
lightened fly wheel
balenced crank
940 head
sw5 cam
standard rockers with fixed spacers
t2 turbo? (unsure)
custom mainfold so don't have to box it
standard box maybe x pin diff
standard drops
Intercooler
front mounted rad? maybe
:) what im thinking for now
100% on the hardened washers
i have fitted one for piece of mind- because
for what ever reason (back in t' day) it must have cured whatever problem they had because it became the thing to do
i wouldnt bother with the strap you have linked because it looks 1/4 inch thick at best, if you are going to fit one fit the biggest one that you can make fit
Chalkie
Member #: 9764
Northamptonshire.
Okay Ill use them then :) thanks guys is what ive listed good enough?
bennyy
Member #: 9037
Doncaster, yorkshire
I also have one, just for piece of mind
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
Chalkie
Member #: 9764
Northamptonshire.
Its for my 998 so don't think it be needed going to go with Phils option of stronger bolts and washers :)
