Home > Technical Chat > Which is better at cooling, Metro rad or mpi Rad?
I fitted an MPI rad to my car last year and it ran too hot for my liking 80-85 degrees, So put the ever faithful minispares 2 core one back on and it stays nice and cool never more then 74 degrees. I run a 74 degree stat so obviously the cooling system is worked a bit harder, especially when it is a hot day.
I also have metro radiator, (not turbo) and wondered whether the metro one is any better.
The way I look at is is while the metro one has more surface area and a little more capacity, it is made of steel, not aluminium, so surely will not give heat up as easily.
has anyone done a direct swop between the two? Or put simply can the metro one keep things cool enough in traffic on a hot day?
What I don't want to do is butcher the front panel any more and then have to go through all the hassle of fitting the side mount again if it doesn't work!
Thanks
James
the metro one deffo, due to its about twise the size.
i went to watch the 7's and migs at Silverstone last year and all the 7's i got a sneak peak at had metro rads
dev 11
Member #: 9393
stoke on trent
85 isn't really hot though really
shellspeed
Member #: 9580
Surrey
Mpi rad only just worked on mpi's which is why you can get supercool versions as a solution to the issue. They have an updated core design similar to that of the mini spares side mount
In what context?
mpi rad was not upto it on the van. we put a chinq rad on it. job done.
90 degrees is normal operating temp for most engines
bennyy
Member #: 9037
Doncaster, yorkshire
85deg is far from too hot.
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
My mpi rad couldnt cope with the standard mpi, as soon as you pulled up at a set of lights the fan was on
rick
I measured the capacity of metro and mpi earlier and they actually both measured out at the same - about 550ml.
On another note while above 80 degrees isn't really hot, I'd like the temperature to remain relatively consistent.
Andy500
Member #: 2443
Cheshire
I ran a standard mpi rad on my supercharged 1293 engine. It coped perfectly well which was a suprise really as the charge temperatures were high as well!
I used to run it between 90 and 95 though.
In what context?
In the context that unleaded fuel burns better with engine temperatures above 90c.
Running engines at 70 or 75 degrees these days is an outdated throwback from leaded four star back in the 70s and 80s.
Edited by Sprocket on 26th Jun, 2012.
Well that is interesting.
Is that to say then that there is potentially some more power to be found running at more like 85 nowadays then?
Edit: don't know why I'm asking. I'm off to do some research!
Edited by minimole23 on 26th Jun, 2012.
Alex
Member #: 1851
Woolavington, Zummerzet
rick
Errr, that's because that's how it works !
An MPi rad doesn't have a mechanical fan constantly blowing air through it like a side-mount does, so the moment the airflow through the rad drops (pulling up to a set of lights perhaps) the fan comes on to compensate. It's exactly the same as a Metro, or and other modern car.
The fan on my MG-260 comes on almost before I have come to rest, and the rad on that is enormous.
metroturbo
Member #: 989
North Yorkshire
I have never had a car where the electric fan comes on as soon as you stop moving, and that includes the metro.
alpa
Member #: 2093
Grenoble, France
I have a front mounted Metro rad (with interleaved fins), restrictors on both bypass and turbo cooling and the 88C thermostat all year long (from -10C up to 35C and on track). Temperature stays at 78-80C. The car was built 2 years ago I think.
