| Home > Help Needed / General Tech Chat > How to de-rust a petrol tank? | |||||||
869 Posts Member #: 2443 Post Whore Cheshire |
25th Jun, 2012 at 10:05:44pm
Hi gents
25th Jun, 2012 at 10:34:35pm
Half a pound of nails and paraffin shaken not stirred. Then flush with paraffin and finally petrol
26th Jun, 2012 at 06:25:03am
Brilliant, thankyou steve will give it a go! |
26th Jun, 2012 at 07:16:40am
www.paint-strip.co.UK On 11th Feb, 2015 robert said:
26th Jun, 2012 at 09:25:49am
Also if you look on eBay you can get a 2 pack sealing paint you swish around in the tank mainly for motorbikes this seals it compleatley gives a nice coat on the inside.
26th Jun, 2012 at 02:12:08pm
Not all fuel tank sealants are resistant to ethanol, so be careful here.
![]() 673 Posts Member #: 1395 Post Whore chepstow |
26th Jun, 2012 at 04:19:36pm
frost do a tank repair kit which is good
26th Jun, 2012 at 04:20:47pm
![]() 641 Posts Member #: 9937 Post Whore somewhereintheuniverse near selkirk scotland |
26th Jun, 2012 at 06:05:21pm
had a yamaha fizzy moped with a very rusty tank and i used vinegar to clean it the cheap bulk buy stuff at tesco is good i used a gallon of the stuff and the results were amazing it was back to new condition ,i couldent belive the results try it mate give em hell |
319 Posts Member #: 1742 Senior Member essex |
26th Jun, 2012 at 06:11:35pm
we have had trouble with the frost stuff it dosent seem to be that resistant to ethanol there are some others that are better but i would try other stuff before coating. My small bore turbo project http://www.turbominis.co.uk/forums/index.php?p=vt&tid=473901 |
26th Jun, 2012 at 06:53:32pm
Im in the process of trying to sort it out with the seller at the moment, but if I do end up keeping it thewn i dont think i will seal the tank and i think the only reason its rusty is because its sat unused since the 70's!
26th Jun, 2012 at 08:09:51pm
hi andy let the vinegar sit in the tank for at least 24 hrs with the cap on say a gallon in it sit it right way up for 24 hrs then on each side for 24 hrs each time im sure youl be amazed at the transformation give em hell |
318 Posts Member #: 9408 Senior Member Tiptree, Essex |
27th Jun, 2012 at 07:39:40am
Use small link chain instead of nails, no chance of leaving any behind when you empty it out then. www.topcatcustom.co.uk |
