| Home > Wanted > Rubber cone compressor in swindon/wootton bassett | |||||||
1492 Posts Member #: 9468 Post Whore Wootton Bassett |
26th Jun, 2012 at 12:54:04pm
Hey guys I need to borrow/rent a cone compressor asap really, trying to rebuild my subfame and found that I need it :/ Im in wootton bassett atm
Hypothetically speaking, where would you stick your nozzle? On 22nd Jun, 2012 apbellamy said:
my wife doesn't know what.head is never mind compression ratio. |
26th Jun, 2012 at 03:09:58pm
Are you using Hi los? |
756 Posts Member #: 1355 Post Whore Leicester |
26th Jun, 2012 at 04:36:25pm
come get mine lol |
26th Jun, 2012 at 04:41:55pm
If your coverting to hi los just smash the trumpets up! There only cast things so just bust em! 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
26th Jun, 2012 at 04:49:34pm
no just trying to install the suspension arms, the wont physically fit back in the subframe with the rubber cone in
26th Jun, 2012 at 04:54:27pm
If you are using hi los wind them all the way in :) I always put the arms in first before the cones and tumpets |
26th Jun, 2012 at 05:15:48pm
26th Jun, 2012 at 05:55:03pm
Yah big jessie get some hi los in there! 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
26th Jun, 2012 at 05:57:38pm
apbellamy told me I would stull need a cone compressor if I bought hi lows (which are about the same price/cheaper than a compressor tool)
![]() 825 Posts Member #: 9661 Post Whore Sheffield South Yorkshire GB. |
26th Jun, 2012 at 06:50:36pm
If you are going to use hi lows, you would only need compressor to dismantle, but you say there already striped down, so no need for compressor.. Main Build
26th Jun, 2012 at 07:53:20pm
I needed to compress my front cones to get the arm with hi los, but I was using brand new cones On 11th Feb, 2015 robert said:
26th Jun, 2012 at 09:02:29pm
You do have to compress the shit outta new cones to get hilos in and to a sensible height to compensate for the sag. They're about £15 from minispares iirc On 26th Jan, 2012 Tom Fenton said:
