Home > For Sale > Mini turbo project, Red hot shell
Rickus
Member #: 9709
Cirencester, glos
Engine
1293 block which has been bored
Omega turbo pistons with 11cc dish (new)
crank was lightend and reground with new shells all round
Piper T3 cam with all new followers and new high capacity oil pump.
lightend flywheel
genuine metro turbo clutch and pressure plate
new bolts all round
new high capacity water pump
gear box rebuilt by guess works with correct speedo drive fitted and centre oil pick up added also added was a X pin DIFF
hiff 44 carb rebuilt
brian slarke modified turbo head with 30cc chambers and polished and ported (very nice expensive head)
brand new braided oil feed lines for turbo and filter head to block.
enlarged exhaust elbow and manifold with brand new 2" exhaust
vernier piper duplex timing kit
metro turbo electronic distributor
T3 turbo but needs a reseal as is smokey
Super cool 2 core rad fitted with better fan blade
The engine has never been driven on the road and has only ever been started, the engine wil need a rolling road set up to make sure it is running correctly.
I have proberly missed somethings with the engine parts.
Car
brand new metro turbo vented calipers 8.4"
new braided brake hoses front and rear
heavy duty adjustable bottom arms and tie rods
rear adjustable camber brackets
fully poly bushed
all new raidius pins and bearing and top arm pins and bearings
subframes hammerited
standard brakes on the rear but overhauled and inspected.
6 point roll cage
bucket seat and harnesses
switch panel with gauges (boost, water, oil, rev)
inside painted out in hammerite
fiber glass bonnet.
12 x 6 revolution wheels with good tires
migilia arches, adjustable hilo's and 14 point ajustable spax lowered dampers.
SHELL SPRAYED IN SATIN RED
The car still needs some work to be completed but most of the hard work has been done. The car does run but has an ignition fault and once the key is released it stalls unless there is a permanant 12v supply to the coil.
Jobs left to do.
Bonnet needs attaching
rear fog light
boot pins need securing on boot lid
ignition fault
sun roof needs putting back in
front arches need trimming for clearence for wheels.
tracking.
And maybe a few other small bits
£2000 . ONO
Car located in cirencester Glos. will need to be trailored away as has no tax or mot.
Contact Rick on 07966762642
Edited by Rickus on 26th Jun, 2012.
adrian
Member #: 2726
wakefield
Hi mate, I'm interested in this and am going to work on my lass about this tonight. Fingers crossed.
Adrian
Rickus
Member #: 9709
Cirencester, glos
Ok mate good luck lol
