| Home > Beginners Tech > Crankcase breathers for a Sprite | |||||||
3 Posts Member #: 10015 Junior Member Blackpool |
29th Jun, 2012 at 02:28:10pm
I've used the search button honest, but...
29th Jun, 2012 at 04:21:25pm
have a search for Tadge44's build; he is running an inline set up and may be able to shed some light on your issues |
29th Jun, 2012 at 05:14:29pm
I might save you some time here.
29th Jun, 2012 at 05:17:31pm
Yes the turbo assembly is heavy and no, I dont think anyone has had problems with the manifold studs giving way. |
2nd Jul, 2012 at 02:55:40pm
Thanks Tadge, Rob.
![]() 864 Posts Member #: 951 Post Whore Bromsgrove |
2nd Jul, 2012 at 03:32:02pm
David covers all the points.The key is a tight rear main bearing clearance and a scroll/cap in good condition.Mine takes a beating and I renew the bearings every 2 years- the rear main is well worn in this time. 'Where does the engine go?' |
