Home > Help Needed / General Tech Chat > whats the best mapping system
page90jack
Member #: 9951
BRIGHTON
hi there whats the best mapping system to get rid off the dizzy?
MarkGTT
Member #: 1194
Shropshire.
just to get rid of the dizzy - megajolt, if using a carb.
If your using a carb any programmable ecu will be fine.
page90jack
Member #: 9951
BRIGHTON
http://www.ebay.co.uk/itm/Complete-Megajol...=item4aa8d4b9c7
page90jack
Member #: 9951
BRIGHTON
page90jack
Member #: 9951
BRIGHTON
is this the one?
Mike-998
Member #: 9774
Buckinghamshire
That's the one, but although it's from a reputable supplier, If you're up to a bit of shopping around, the ford bits can be aquired from a scrappy/ebay for next to nothing, I used this man for the trigger wheel:
http://www.ebay.co.uk/itm/TRIGGER-WHEEL-LA...#ht_927wt_1139;
made you your specifications, and the Megajolt itself can be bought from the manufacturer and shipped for less than the triggerwheels price I believe:
http://www.autosportlabs.net/Main_Page
also, a bit of browsing on the above website will give you all the info you'll need about the parts you need, and how to wire them up.
