| Home > Help Needed / General Tech Chat > K head clearance to stock Mini water pump | |||||||
![]() 85 Posts Member #: 2234 Advanced Member Palm Beach Gardens, Florida |
30th Jun, 2012 at 09:48:42pm
I did try the search engine here, but did not find the answer. Also, I can not figure out how to eliminate words from the search, I tried to keep it from finding threads about electric pumps but it won't do it.
Edited by scooperman on 30th Jun, 2012. |
30th Jun, 2012 at 10:03:39pm
You need to cut the webbing out of the pump to clear the belt.
1st Jul, 2012 at 09:19:14pm
The pump just starts to foul the head on 1275 blocks depending on final deck hight and head gasket combination. The shorter 850 block will most certainly casue the pump to foul and will need filing a bit Edited by Sprocket on 1st Jul, 2012. On 26th Oct, 2004 TurboDave16v said:
2nd Jul, 2012 at 11:50:03am
Matty and Sprocket, thank you. I did keep milling on the pump until it fit, quite a bit needed to be cut. Its an old pump which I don't mind sacrificing for science.
2nd Jul, 2012 at 09:53:01pm
Meanwhile, back at the water pump....I whittled on the 998 (no bulge) water pump just to see how much it would take to make it fit between the 850 block and the BMK K head. Then I moved the head over to an old 1275 block. Now I have plenty of height clearance, but I hate the belt (outward from block) clearance. I would like to move the pump inward toward the block about 5mm. So my thinking now is either mod the pump, throw away the pump and go electric, or do a custom billet pump housing and put the guts of a stock pump in it. Stay tuned. |
