Home > For Sale > 2.9:1 Crown wheel and pinion, A plus crank, MPI Rad
I Need to free up some space so getting rid of some stuff I'll never use.
I have a 2.9:1 cw&p removed from a 45k 998. £70 plus post.
A 1275 a plus crank that needs a grind. Good taper. £25
I also have an MPI rad with all the hoses and the thermostat housing. few bent fins but otherwise fine £40
I'll get some pics up later on.
I can bring everything to mini in the park, and even Castle Combe in September if you wish to wait that long.
Thanks
James
Edited by minimole23 on 1st Jul, 2012.
would like that crank mate, you doing an shows (mitp)?
Its yours, I'll wrap it up and put it away again.
I will indeed be doing mini in the park.
cheers buddy
minidan
Member #: 7107
essex
ill take the mpi rad and bits ill collect a mitp if thats cool with you
