| Home > Technical Chat > Slave cylinder | |||||||
39 Posts Member #: 10008 Member Tamworth |
1st Jul, 2012 at 08:15:10pm
Can I use pre verto slave cylinder in verto clutch set up ? |
1st Jul, 2012 at 08:20:18pm
yes, but the hose thread is different, so you'd need the hose too. On 28th Aug, 2011 Kean said:
2nd Jul, 2012 at 07:32:09am
For the hose, mini verto slave is 3/8 unf. metro verto slave is m12 x 1. On 11th Feb, 2015 robert said:
2nd Jul, 2012 at 07:48:19am
I thought they were all cable operated on the Metroid andy? 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
2nd Jul, 2012 at 08:00:51am
MK1's were hydro. Very early ones were even pre-verto. If something is worth doing, it's worth doing half of. |
2nd Jul, 2012 at 08:01:39am
early ones where hydraulic, we had to convert the van as the cables won't cope with much more than standard clutches On 11th Feb, 2015 robert said:
2nd Jul, 2012 at 10:15:02am
Basically I'm sure it's a pre verto slave cylinder I have bought the wrong one by mistake but just wondered what the actuall difference was between them ? And can I use it ? |
2nd Jul, 2012 at 12:31:10pm
The only real difference is where the bleed nipple is located On 11th Feb, 2015 robert said:
2nd Jul, 2012 at 01:04:26pm
arnt they different bore's too? Yes i moved to the darkside |
2nd Jul, 2012 at 05:37:12pm
only very slightly different, not enough to make any reall difference
