Home > Beginners Tech > Stupid question?
edward92
Member #: 10012
East Yorkshire
Hi, My name is Edward :) my plan is to build a Turbo A-series engine for my Morris Minor, yes i know it's not the same as the mini and I am using a Morris engine but I thought I'd be able to seek help from you guys as they're essentially the same.
My first stupid question: Are the turbo & the exhaust manifold the same?
Looking at that I don't understand how you could connect it or use as well
Any help appreciated,
That's a T2 on a Metro manifold with a home made elbow attached to the turbine.
It will be pretty easy to make a new albow with the flange you have there.
A number of folk on here have turboed in-line motors (midgets and an A35) so it wil all go.
bennyy
Member #: 9037
Doncaster, yorkshire
If I understand correctly, no, you need a turbo manifold for a turbo.
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
edward92
Member #: 10012
East Yorkshire
So to do this I would use the manifold already attached to the turbo and the pipe coming off it would connect to the rest of the exhaust?
Thanks
That's correct yep :)
Nothing is a stupid question if you need to ask it. Otherwise, you really will look stupid when you cock it up and have to ask afterwards. That's how i see it anyway.
Good luck with the build!
Ben H
Member #: 184
Melton Mowbray, Pie Country
Yes, basically you need the entire metro turbo setup and bolt it on. The make an exhaust to fit.
There is a little more to it than that, but that answers you question.
http://www.twin-turbo.co.uk
edward92
Member #: 10012
East Yorkshire
Alright thanks guys :) That has helped clear up a lot of confusion, hopefully a smooth rebuild and turbo project from here :)
lets see some pic's of your moggy then
edward92
Member #: 10012
East Yorkshire
It's currently fairly standard, although I have these wheels to put on when arch extensions come on Thursday but also need slightly longer wheel studs, the wheels are 8jx13's
Nowhere near immaculate but I wanna go fast (er)
looks good. we're more about go than show on here *smiley*
edward92
Member #: 10012
East Yorkshire
I'm thinking I might build the rest of the engine how I want it and take it to a garage or somewhere to get the turbo unit put in as it still baffles me :)
To simplify.
The exhaust ports from the head must come together and enter the turbocharger.
They then exit the turbo and out to the rear of the car as normal.
There are many ways to achieve this, at various costs.
Edward come and have a natter and a brew at the benross HQ pm me
bennyy
Member #: 9037
Does this help? Turbo on a metro turbo manifold, with the exhaust downpipe attached,
then as they are oil cooled, you need an oil feed:
And an oil drain
We can help you on the above when it comes to it, pop over to Steve's, once you see an engine on the bench it will all become clear
edward92
Member #: 10012
East Yorkshire
PM'ed you benross and yeah, thanks benny :)
