| Home > Help Needed / General Tech Chat > Turbo Minis and gearboxes? | |||||||
27 Posts Member #: 533 Member |
22nd May, 2005 at 10:47:14pm
Hi, |
22nd May, 2005 at 11:00:48pm
with that sort of power i would expect the gearbox to last quite some time as it is normally the diff pin which goes first, obviously with the cross pin you will solve this problem, i would just get a rebuild kit and make sure the bearings etc are all ok. |
22nd May, 2005 at 11:03:14pm
I will be using a freshly rebuilt gearbox |
![]() 1128 Posts Member #: 142 Post Whore Winchester |
22nd May, 2005 at 11:04:43pm
good call on the diff, my girlfriends diff pin went a few days ago and put a nice hole through the sump |
23rd May, 2005 at 01:39:20pm
KK - If you rebuild the box, replacing anything that looks dubious (layshaft, bearings, etc) then you'll have plenty of fun!
23rd May, 2005 at 01:44:19pm
That will be my intention to put in a different final drive whilst I am there. this isn't going to be happening for qutie some time, but I was told I'd munch gearboxes because of the torque produced by turbos. I just wanted to see what you guys thought.
23rd May, 2005 at 11:58:48pm
all info on this site is turbo related the search is the best thing to use |
24th May, 2005 at 08:19:58am
Beginners guide thing is handy |
27th May, 2005 at 08:20:53am
My gearbox has seen about 70000 kms, 50000 km with turbo engine. Boost at 10 psi, last 3 summers at 16 psi. I took it apart 20000 km ago, and had to reset laygear, idle gear and primary gear end floats. I also replaced the primary gear since the bushes on the old one were worn. It was s/h when I fitted it and had done unknown mileage (100000+ km).
27th May, 2005 at 10:15:32am
Think you get the idea that you will be fine with a recondtioned box but i will just add that i ran my normally aspirated 1380 for 2 years (108bhp) with a standard recon gearbox, it was my everyday car and got plenty of abuse:) The only bit of wear was the diff pin, ok not as torquey as a turbo with similar power but cant see you will have any problems. -MINI CLUBMAN 1380 TURBO- |
