Home > Help Needed / General Tech Chat > fuel pump suggestion.
clubbie70
Member #: 8935
netherlands
I am in need off a fuelpump for around the 160 bhp mark.
Now i know that the 058464070 bosch pumps are ok.
This pump has fuel lines which connect with clips. I would like a pump with those same specs that connect to those fancy connectors that you can screw on.
anyone has an idea??
thanks
I'd say anything rated to 3bar will do everything you can throw at it.
clubbie70
Member #: 8935
netherlands
yes i know ....but they all have push on connections.....
Try demon tweeks, i had a quick glance earlier and look like they have the option of screw on or push on.
jamie@thefatgarage
Member #: 9345
Sheffield
Whatever you buy, avoid the cheap "bosch" ones on ebay for around the £30-£40 mark. Had 3 out of 4 pack in that I've had in the past.
clubbie70
Member #: 8935
netherlands
would this one be any good for the power i require?
think it has the same figures as the standard metro turbo pump.....
http://www.fuelpumpsonline.co.uk/bosch-fue...54979-188-p.asp
jamie@thefatgarage
Member #: 9345
Sheffield
That's an injection pump. Are you using injection?
clubbie70
Member #: 8935
netherlands
nope....carb with return line offcourse..
would this pump give a prolem then??
jamie@thefatgarage
Member #: 9345
Sheffield
No, with a regulator that can control it. I've never stuck 45psi into a standard metro turbo reg, maybe someone has on here. You could save some money by using a pump for a turbo/carb car.
Lots of people use mpi pumps with fpr's. It's what i intend to do, that's an injection pump.
clubbie70
Member #: 8935
netherlands
the problem is i want to use thos screw on fittings on the pump... This is the only one i could find with an output of 3 bar... with those fittings.
So it could also be used with the standard fpr in my opnion.
I can buy this pump(original bosch ) a lot cheaper ...
But i want to know for sure if it works....
jamie@thefatgarage
Member #: 9345
Sheffield
Why do you need a 3bar pump for a carb?
clubbie70
Member #: 8935
netherlands
its not that i need a 3bar pump.... but those are the same specs as the original metty turbo pump,..
If you have a better suggestion with the connections i mentiond..please let me know
A 1 bar pump isn't enough to run more than say 11psi boost. I want to run 17psi, And therefore an spi tank with mpi pump is the best option for me. The fuel pump needs to supply boost pressure + 3ish psi. It's probably much easier to get hold of a 3 bar pump than a 2 also for certain applications.
The Metro regulator can cope with a 3 bar pump.
jamie@thefatgarage
Member #: 9345
Sheffield
In that case buy this and save a few ££
http://bit.ly/PFAY6Q
The regulators are spillback so, providing the return line is large enough, the pump will never run at 3bar (45psi), it will just flow 3.4 l/min through the regulator (most going back to the tank, not to the engine) with the pressure being whatever the regulator says (setting plus boost).
160HP requires, worst case, flat out all the time, approx 1.2 l/min so the pump is more than adequate.
This is what you want then:
http://www.merlinmotorsport.co.uk/p1997/SY...oduct_info.html
It's actually a Walbro 255 with JIC connectors.
