Home > Help Needed / General Tech Chat > turbo issues?
turbo22
Member #: 3684
wisborough green west sussex
I have been running my new build engine in for a while now and have been having some issues with the turbo. First of all after a few trips out the turbo started making a high pitched squeeling noise like a boost air leak or similar.I checked everything and all was fine with connections etc, slowly the noise has become more regular and today i turned the boost up a little for the first time and the turbo seemed realy weird, some times it would boost and some not. when I got home and sat on idle it smoked badly and stunk realy oily. I have taken the intercooler pipe off the turbo and there is LOADS of metal filings in the pipe with a tiny bit of oil. Does this mean my turbo is royley fucked???.
If so who is the best person for a rebuild and do you get money for exchange turbos as i have two?. Greatfull for any help.
Cheers.
Your turbo is definitely fucked.
I rebuilt mine myself. It's pretty easy, but not exactly cheap once you consider balancing etc.
Sounds fucked to me.
turbo22
Member #: 3684
Bollocks thats what i thought. Isnt there someone on here called turbohogster or something that does rebuilds?. If not can anyone recommend someone down south.
If im gonna rebuild it i want the works.Whats the best mods to do?.
Ta
Craigie-B
Member #: 9468
Wootton Bassett
You can buy the cores for £300 odd off of ebay for a t2 or a t3, then you can take the housings off and just swap out the core :)
http://www.ebay.co.uk/itm/Garrett-T3-T34-T...=item4aa51a1330
turbo22
Member #: 3684
Ill look into that now cheers.
turbo22
Member #: 3684
right all apart and turbo off and bingo found the problem. small nut on the end of the impellar had come off and was wearing away at the impellar. thats as far as i have got but i guess the bearing has gone too as there is a small amount of oil and the shaft has a lot of play end to end. Hopefully AVR classics is open tomorrow and ill pay them a visit. Its about £500 for there top spec t3 hopefully they might give me a little off as i have two t3's to exchange.
Yes its goosed. .lol
turbominivanman
Member #: 1504
Westbury, Wiltshire
Try Universal Turbos near Salisbury.
Did a fab job on mine.
Here's a link :
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=230677
turbo22
Member #: 3684
thanks guys
If your after a T3 I will part with mine if you want. I'll never use it.
turbo22
Member #: 3684
pm'd
