Home > Technical Chat > Land Rover Turbo
MaltaMini
Member #: 510
Malta
Guys, If I was to use a T25 off a Land Rover tdi engine, on a Mirage manifold, would I get some good power, or am I better off with a T25 from some other car?
I donated, but somehow didn't get the label! :(
dan
Member #: 93
go for the tried and tested r5 unit, found this earlier, the brand new option isn't that ridiculous after all
http://www.turboactive.com/sess/utn;jsessi...urbo.shopscript
MaltaMini
Member #: 510
Malta
OK - now which one should I go for? Some are water-cooled, which isnt a bad idea? Any mods I should do to it? 360 degree thrust washer?
dan
Member #: 93
the cheap one would be best i'd say
R5 Turbo 1.4L P G 87-90 465367-1/2 W N Please Ring £ 266.10
the 360 thrust washer will maintain the turbo's longevity but i doubt you'll need it, based on past experience with r5 turbo's you should see about at least 15-20kmiles running 15psi
my mate managed to get over 30kmiles out of his fiesta turbo running over a bar of boost
if you want a tweaked turbo talk to the supplier about what you want to use it for and they should know if it needs any upgrades or not
