Home > General Chat > silicone hoses.
1293 sprite
Member #: 5449
Melton Mowbray
Hi
To complete my intercooler setup I need a silicone hose to join two ali pipes. The problem is they are offset so a straight pipe won't bend enough and a 45° is too bent if that makes sense. The angle id need at a guess would be about 25°. Can't seem to find anywhere that sells a similar pipe, everywhere seems to be 45, 90, 135 180 etc. Any suggestions where I could get one from please?
Thanks in advance.
1293 88.8hp 82.2ftlb
17.3 1/4 @ 78 mph
Naturally Aspirated (for now)
kelvg
Member #: 3277
whetstone, leicester
Cant you use the anti kink straight lenghts ?
1293 sprite
Member #: 5449
Melton Mowbray
Not seen that before, sounds like it may do the trick though if its flexible! Where can I get some from please?
17.3 1/4 @ 78 mph
metroturbo
Member #: 989
North Yorkshire
http://stores.ebay.co.uk/Auto-Performance-...?_fsub=11880357
1293 sprite
Member #: 5449
Melton Mowbray
Thanks for the link, I saw this but it looked like low pressure pipe for air filter to turbo etc. doesn't look like it will take 37bar like it says!
17.3 1/4 @ 78 mph
welshdan
Member #: 1111
s wales
I use these hoses on my setup i believe others on here do too....
Edited by welshdan on 8th Jul, 2012.
bennyy
Member #: 9037
Doncaster, yorkshire
Go to a local exhaust place and have some stainless bent.
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
paneermeel
Member #: 1404
The Netherlands
perhapse something like this would do the trick:
http://www.biesheuvel.nl/store/group/2148/mega_flex
there is nothing wrong with a A-series that a turbo can't fix.
www.turbomini.nl
1293 sprite
Member #: 5449
Melton Mowbray
Thanks for all advice, going to try some of that flexible silicone piping. I'll update with pictures when its done!
17.3 1/4 @ 78 mph
Johnny
Member #: 6926
Accrington
http://www.ebay.co.uk/itm/51mm-2-Silicone-...#ht_1376wt_1163
???? would that work
1293 sprite
Member #: 5449
Melton Mowbray
I looked at that, but its not long enough. Probably needs to be about 8" long.
17.3 1/4 @ 78 mph
