| Home > Help Needed / General Tech Chat > Anti Lag variant | |||||||
![]() 690 Posts Member #: 9962 Post Whore |
10th Jul, 2012 at 05:32:01am
Non A series but interesting video of another flavour of Anti Lag
Edited by Aubrey_Boy on 10th Jul, 2012. |
12th Jul, 2012 at 09:50:21am
So what's new about it ? 9.85 @ 145mph
976 Posts Member #: 3228 Post Whore North of the Netherlands |
12th Jul, 2012 at 11:05:37am
Out of curiousity; how does it work? Dazed and Confused.... |
12th Jul, 2012 at 11:14:32am
This one tastes abit different :) Yes i moved to the darkside |
12th Jul, 2012 at 11:20:15am
They usually retard the timing to allow full throttle without revving straight to the limiter. Sometimes 50-60 deg but variable obviously..
On 12th Jul, 2012 Yo-Han said:
Out of curiousity; how does it work? |
12th Jul, 2012 at 12:00:59pm
Its based on the WRC 'Rocket' system and is hence a 'proper' hardware implementation of Anti Lag as opposed to just mapping changes.
Edited by Aubrey_Boy on 12th Jul, 2012. |
12th Jul, 2012 at 12:21:28pm
is this something your involved in ?, im interested of system diagrams and maybe a step by step of how it does what it does Yes i moved to the darkside |
12th Jul, 2012 at 12:24:46pm
Hi Brett,
12th Jul, 2012 at 12:28:32pm
cool, ill stick with mine not that i use it much tires start crying Yes i moved to the darkside |
12th Jul, 2012 at 12:40:49pm
How effective are the 'software' based systems, i.e. how much boost could be delivered at tickover with an otherwise normally running installation? |
12th Jul, 2012 at 01:25:15pm
at idle i doubt much at all, mine starts to build boost on 'antilag' from about 1500 upwards but needs a very aggressive setting, at 3500 i can have almost any boost i want in about a second on quite a tame setting but its still extremely hard on the turbo and useless to launch on...
207 Posts Member #: 193 Senior Member Aylesbury |
12th Jul, 2012 at 10:01:33pm
I have been out in this car and i must say its pretty impressive. Its been an ongoing project over the lasst year or rwo. |
12th Jul, 2012 at 10:11:31pm
Brett how does your flat shift work? Have you got a switch on the clutch pedal or something? https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
12th Jul, 2012 at 11:47:53pm
i set up a slide resistor on the clutch plunger with 0 + 5v either end( might have been 12v) and fed the output into a voltage comparator circuit, had that comparing against a variable resistor of the same set up, this outputs an earth onto the launch pin on megasquirt
13th Jul, 2012 at 10:51:02am
I was thinking of just using a brake light switch on the clutch pedal and an on off switch on the dash to enable/disable it. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
13th Jul, 2012 at 01:25:32pm
Hi Luke,
.. Edited by Aubrey_Boy on 13th Jul, 2012. |
13th Jul, 2012 at 02:01:42pm
On 13th Jul, 2012 matty said:
I was thinking of just using a brake light switch on the clutch pedal and an on off switch on the dash to enable/disable it. The switch does work but getting it in the right place is the key to smoothness i still think its a little hard on gears well everything really i may try it a gain at some point but spending time setting it up / working out the rpm drops in each gear Yes i moved to the darkside |
15th Jul, 2012 at 09:15:02pm
Moved on to Cosworth.
On 13th Jul, 2012 Aubrey_Boy said:
Hi Luke, You still at Junc 11... Or moved on? I should be catching up with Mr ZeroLag on Sunday, not sure if he will have the car with him or not though Cheers |
16th Jul, 2012 at 06:47:38am
Hi Luke,
