| Home > Help Needed / General Tech Chat > rearmost rear trunions | |||||||
10th Jul, 2012 at 09:10:50am
Does it matter which way round they go? long bolt v short bolt at the rear. On 11th Feb, 2015 robert said:
10th Jul, 2012 at 09:16:16am
the ones on my mini are the opposite way to the ones on my spare subframe
Yes i moved to the darkside |
10th Jul, 2012 at 09:22:00am
been having a bit of trouble getting my rear frame in (yes I tried it before final welding when I replaced the whole rear end). was wondering if they where dimensionally different one way to the other. On 11th Feb, 2015 robert said:
10th Jul, 2012 at 11:09:45am
They are dimensionally different from what I can see by eye, the centre of the bush hole is closer to the larger bolt if that makes sense :) |
10th Jul, 2012 at 11:16:23am
thanks. going to try them the other way round On 11th Feb, 2015 robert said:
10th Jul, 2012 at 03:02:29pm
Did it all fit ok now? Yes i moved to the darkside |
10th Jul, 2012 at 04:15:53pm
no, but then I haven't been out to the garage yet... On 11th Feb, 2015 robert said:
10th Jul, 2012 at 05:05:13pm
Sorted. Had the rear trunion bolts fully tightened up. As soon as I slackened them off it released the tension and allowed the subframe to lift into the right spot. Time for some radius arms, shockers and some wheels. On 11th Feb, 2015 robert said:
