Page: |
Home > Show Us Yours! > Supercharged Pickup | |||||||
3rd Aug, 2012 at 11:21:43am
On 3rd Aug, 2012 remko said:
As I use a weber-style throttle body it's not possible to use speed density as a single table. I use an alpha-n table (TPS) and from manifold pressure 70 I will sum that with a speed density table. I don't think the problem with megalogviewer is licence, but the fact that I use a combination of 2 ve tables. You could be right, it's not a combination that I would ever have thought of using. But I do use two (different) VE tables as, apart from injection timing, it's one of the ways to balance inner and outer AFRs, and I have no problem with data/displays. More interestingly though, if you don't measure inners and outers - and are running the siamese code - how do you decide where to set the individual inj timing and VE values ? The fabrication looks very neat by the way but if you are trying to do port injection I personally would have put the injectors a lot closer to the ports and removed the balance pipe (but that would then make speed/density hard to read...). Schrödinger's cat - so which one am I ??? |
75 Posts Member #: 1956 Advanced Member |
3rd Aug, 2012 at 02:37:18pm
Using the 2 tables wasn't my idea either, the guy at BS-autotune came with the idea and it seams to work.
967 Posts Member #: 3228 Post Whore North of the Netherlands |
3rd Aug, 2012 at 02:44:27pm
Remko, have a look at this thread by Paul S for hooking up two O2 sensors:
Dazed and Confused.... |
29th Jan, 2013 at 07:03:10am
Update:
29th Jan, 2013 at 07:41:46am
NICE! mate ive always loved the ute and body hard to get one over in Aussie land.. |
29th Jan, 2013 at 09:01:55am
Overhere in Holland it's not easy too.... I was just very lucky someone offered me one :) |
20th Apr, 2013 at 06:15:47am
Update:
Edited by remko on 20th Apr, 2013. |
4th Jan, 2014 at 11:50:25am
Update:
537 Posts Member #: 8926 Post Whore Sheffield |
4th Jan, 2014 at 03:16:09pm
awesome looking pick up remko |
6th Oct, 2020 at 04:34:37pm
It's been a while since I updated this post. I changed the setup since last post. Removed injection, went to more retro Hiff44.
Edited by remko on 6th Oct, 2020. |
51 Posts Member #: 10080 Advanced Member Holland, Eindhoven |
7th Oct, 2020 at 08:48:32am
Looks good but sounds much better. |
7th Oct, 2020 at 09:13:23am
Gaaf!
On 6th Oct, 2020 remko said:
It's been a while since I updated this post. I changed the setup since last post. Removed injection, went to more retro Hiff44. Current setup is as following: 1275 with flowed head (35.6 inlet, 29 outlet) and Kent 276 camshaft Front mounted supercharger (0,5 bar / 7psi) Side mounted Toyota MR2 intercooler Volkswagen G40 recirculation valve Blow through Hiff44 DIS coil KDFI ECU Finally it runs like it should! Loads of torque, perfect drivability over total range and full throttle power is great! Have been on the dyno last weekend to optimize spark advance. Result: 120Bhp and 160Nm. Torque curve very flat from 2500 till 5500 Rpm. Very happy with this result! For now this is great, but improvements already planned for coming winter: Upgrade to 1380 engine with lowered compression Upgrade to smaller pulley (0,5 to 0,75bar boost) Dazed and Confused.... |
21st Mar, 2021 at 10:31:22pm
Today I switched to a smaller pulley.
428 Posts Member #: 10128 Senior Member Dorset |
23rd Mar, 2021 at 11:10:55am
Are you planning a trip back to the rollers? Be interesting to see the numbers now. But sounds like the butt dyno is working! |
10th Apr, 2021 at 08:20:15pm
Back to the rollers is certainly the plan. Probably only after summer during MiniProjects dyno day! |
Page: |
