Home > Help Needed / General Tech Chat > Quick shift housing problem
darkviper222
Member #: 9904
Hi peeps.
I have a problem with where my gear remote sits inside my car. As you can see in the picture the handbrake is In the way of operating properly. My dash is the evo 2 from Curley and sits forward in the cabin more so than a standard dash. Any Ideas???? Do I relocate the handbrake??
Any help or ideas would be great.
Thanks
Here is a link to the photo. Hopefully this works!!
Edited by darkviper222 on 14th Jul, 2012.
darkviper222
Member #: 9904
Sorry but I can't seem to upload my photo
wng691s clubby
Member #: 9252
Cleethorpes
are you trying to put the photo up with photobucket?
Done now needs redoing lol
Star Mag
Member #: 375
Leicestershire
I have moved my gearstick further back than the standard position. I moved the handbrake further back using the standard mounts. I recut the floor and shortened the cable.
darkviper222
Member #: 9904
I am trying to add it as an attachment. But it will not upload on to the site?
the image needs to be .jpg... my camera takes photo's as .jpeg and the site wont play with them
just rename the picture with .jpg at the end works for me
wng691s clubby
Member #: 9252
Cleethorpes
i use photobucket.com or what ever it is and just copy the img code
I have also shifted my handbrake back out of the way. If you shorten the quickshift i believe it will hit your dash.
spaceframemini
Member #: 7472
stockton on tees
Same here relocated handbrake further back
Andy
I just bent mine out of the way a bit.
Ben H
Member #: 184
Melton Mowbray, Pie Country
http://www.twin-turbo.co.uk
Oh Really?
Ben H
Member #: 184
I.e. its a grower not a stayer.
darkviper222
Member #: 9904
Thanks for the advice. I still can't upload any photos though and I have tried everything you guys have suggested?
Did anyone have to extend their remote rods because the extra distance?
wng691s clubby
Member #: 9252
Cleethorpes
try this http://www.turbominis.co.uk/forums/index.php?p=vt&tid=7932
Edited by wng691s clubby on 13th Jul, 2012.
Ben H
Member #: 184
I have used an Allegro selector to move it back, but mine is still underneath.
nala56
Member #: 9661
Sheffield South Yorkshire GB.
This is what your post should look like to put pictures on TM, to do this you need to go to photo bucket, hold your mouse over the photo you wish to show, click the second option down, then go back to post reply in TM, select the icon on the right that I have circled in red, when box opens paste your image in, and it should look like the sample shown..
Main Build
Upgrade to Turbo
darkviper222
Member #: 9904
Here is the photo with the problem I face
darkviper222
Member #: 9904
Thanks nala56 for your help with the photo upload
i never knew that... i have always typed the code in and sorted the image link out manually *happy*
edit:.. you can even add links without typing out the code... cooool 8-)
Edited by Brett on 14th Jul, 2012.
