Home > Help Needed / General Tech Chat > quichshift
bawbee
Member #: 191
Falkirk, Scotland.
I have just fitted a quick shift to my gearbox but find I am now unable to select reverse gear. Can anyone tell me where I must have gone wrong?? The installation seemed to be straightforward enough.*tired*
Reverse is always a pain in the arse to find with a quickshift.
Mine got easier with use.
It is (or shoud be) there. All I can suggest is keep fiddling.
Wil
clubman_dan
Member #: 142
Winchester
i found it hard to use my quickshift at first.you soon get sued to it though
adam1330
Member #: 238
essex
same here, when i first fitted my quickshift i thought i would be taking it out again! i actually turned the plate around on the bottom of the selector box thing...so i dont have to lift for reverse any more...which requires a very precise 3rd to 4th gear change..
Carl
Member #: 95
liverpool-on-sea
i may be wrong about this but i seem to remember that you have to shorten the spring so maybe you have to shorten it some more,am i right its a while since i did mine.
p.s mine is difficult to get reverse but a bit of brute force and ignorence is the key*smiley*
Zeemax Power
Member #: 393
Oulton Park
mines a bitch aswell and i've put a screw in on the other side aswell cos the top kept being pushed of grese it heavy in the box works everytime!! and power
http://www.Zeemax.com
bawbee
Member #: 191
Falkirk, Scotland.
Thanks for all the help guys. I took the plate off the bottom of the gearshift housing and I could get reverse ok then, so I just ground down the lug and I don't have lift to select reverse now. Working a treat now. Ta.*happy*
gregor
Member #: 98
Slovenia
i made a quick shift by myself. it works great. even my wife likes it.
Edited by gregor on 31st May, 2005.
Zeemax Power
Member #: 393
Oulton Park
mine likes more than a quick shift lol see what i did there
