| Home > Help Needed / General Tech Chat > Fan Switch On/Off temps | |||||||
1492 Posts Member #: 9468 Post Whore Wootton Bassett |
14th Jul, 2012 at 08:19:05pm
Hey Guys!
Edited by Craigie-B on 14th Jul, 2012. On 10th Mar, 2012 theoneeyedlizard said:
Hypothetically speaking, where would you stick your nozzle? On 22nd Jun, 2012 apbellamy said:
my wife doesn't know what.head is never mind compression ratio. |
14th Jul, 2012 at 08:36:28pm
I'd say on 95 off 88 is the one to have, wouldn't want an engine running at a higher temp.
14th Jul, 2012 at 08:43:30pm
okay thanks bud, will have to have a butchers for a 14mm drill and a 1.5 tap set
14th Jul, 2012 at 09:29:53pm
You don't use a 14mm drill for m14 tap, more like 12.5-13mm. Audi s4 b5 - 470bhp & 486ft lbs
On 15th Mar, 2012 wil_h said:
14th Jul, 2012 at 09:54:43pm
mine currently comes on @96 off @86 with an 82 deg stat i have tried various temps i think the spi/mpi's fans kick in around 105deg
Edited by Brett on 14th Jul, 2012. Yes i moved to the darkside |
14th Jul, 2012 at 10:14:38pm
Fuck I just bought a 14mm Drill bit :@, okay thanks will email the seller :)
On 14th Jul, 2012 bennyy said:
You don't use a 14mm drill for m14 tap, more like 12.5-13mm. On 10th Mar, 2012 theoneeyedlizard said:
14th Jul, 2012 at 10:18:16pm
On 14th Jul, 2012 Brett said:
mine currently comes on @96 off @86 with an 82 deg stat i have tried various temps i think the spi/mpi's fans kick in around 105deg i also have an override switch and honestly the moment i see the temp gauge whisper over 85 it gets flicked on lol On 10th Mar, 2012 theoneeyedlizard said:
14th Jul, 2012 at 10:30:52pm
it will be as ok as the weakest part of the cooling system, i only have the electric fan on mine and it copes rather well considering.
15th Jul, 2012 at 08:33:29am
15th Jul, 2012 at 09:00:41am
