Home > Help Needed / General Tech Chat > Scuttle fitting
Amp
Member #: 7856
Morning all,
I have to replace a full scuttle on a minivan, has anyone on here had experience fitting both genuine and pattern ones of these? It's almost £60 difference between them so if there is not a great deal of difference then the pattern one would suffice!
Thanks
mercenary62
Member #: 9937
pattern one fitted mine ok mate ,no probs
give em hell
not done a skuttle, but I found the majority of the pattern panels I tried on my car where utter shite.
welshdan
Member #: 1111
s wales
Just done a front and and some other parts plus a respray on one of mine. The heritage panela need quite a bit of work to make them fit and line up properly. But from past experience, non gen panels really are a risk, some fit ok, some just dont fit at all.
I fitted a genuine scuttle on mine, mini spares suggested going for the genuine one, and i'm glad i did cause it fitted a treat.
If you want to have a look at the fit drop over, its on my other car with a flip front so you can get a good look at it, can give you some tips too.
Remember that its also down to quality aswell, the steel is better on gen stuff n will last longer
and welds better.
Ive fitted a genuine one, and it fitted perfectly. To be honest its one of them panels that once fitted you wouldn't want to do again. I'd go for a genuine one, just for sake of having better quality metal that won't rot out in a few years.
I used the heritage one on mine and it fitted with genuine wings without issue.
Having said that, I know a few specialists who will use the Hadrian ones quite happily if on a budget
mercenary62
Member #: 9937
yeh mine was a hadrian one ,had no issues with fitting or welding
give em hell
genuine is taller on the windscreen partsd so you have more metal to play with
Amp
Member #: 7856
Thanks for the advice all, I think i'll go for the genuine, I started off with just replacing the corners, but found more rust so am just going to do the whole thing, may as well do it properly!
Joe, when I get round to it, I may take you up on that offer, i'll let you know :) Got to fit the inner wings first!
Edited by Amp on 15th Jul, 2012.
when yoy get to it give me a shout, you can glue it on with my spot welder, ideal for the screan seam.
also, get yourself some spot weld drills, wonderful bit of kit.
Alex
Member #: 1851
Woolavington, Zummerzet
Heritage ones plop straight on, Hadrian bits are crap.
Jackamason
Member #: 10013
Hockley, Essex
I've recently fitted a genuine minispares one to my car and it fitted perfectly, with some help from minidan doing the welding.
