Home > General Chat > glass fibre , removable front front end fitting
mercenary62
Member #: 9937
evenin gents how easy is it to fit a glass fibre front end ,as my mini has already got the inner wings cut out, ive got the subframe brace bars , i need to know what happens at the front bumper area regards bolts /r pins is there a link on here for detailed fitting , ive looked cant find anything detailed
give em hell
I mounted mine using bonnet pins through the brace bars at the front.
You need to elongate the holes in the clip for the pin to slide through due to the angle but that's easy enough.
mercenary62
Member #: 9937
thanks mate looks gr8 thats just what i needed, do you have some rubber in between whats left of inner wing and f/glass front, i take it theres rubber between brace bars and f/glass at bumper area
give em hell
There's some where the wing area meets the scuttle but the clubby front doesn't touch the inner wing tops as the bonnet area is wider.
I didn't need any hose over the front bonnet pins as it sat itself in a way that it wouldn't move anywhere. I could even sit on my front end lol.
