Home > Help Needed / General Tech Chat > Distributor Shaft?
holmesgraham
Member #: 2556
Southport, Merseyside
What is the easiest way of getting the distributor shaft out? Mine has been place in so my lead to cylinder 4 has no slack in it what so ever.
Thanks
Graham
holmesgraham
Member #: 2556
Sometimes my descriptions are exactly great, so to clarify, im talking about the shaft from the camshaft to to bottom of the distributor.
bennyy
Member #: 9037
Doncaster, yorkshire
I always force my finger in, but a bolt screws in, 5/8 rings a Bell, but could be miles out
Scrap that its 5/16unf
Edited by bennyy on 16th Jul, 2012.
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
holmesgraham
Member #: 2556
Cheers! Cracking bit of advice!
Oooh benny, i love it when ya talk dirty!
Mike-998
Member #: 9774
Buckinghamshire
The radiator lower mount bolt is the perfect tool for getting it out, its as if BMC did it on purpose *tongue*
Chalkie
Member #: 9764
Northamptonshire.
make sure you remove the dizzy holder aswell also you may have to turn engine over as sometimes it can hit the crank 1100 engines allways do it to me
turbochargedstu
Member #: 908
gateshead
the std gear lever is also the same thread so screw that in and pull.
balls to the blower!!!
tadge44
Member #: 2500
Buckinghamshire
Or a rocker shaft bolt.
scooperman
Member #: 2234
Palm Beach Gardens, Florida
5/16-24 long bolt screws in to the distributor shaft. When the distributor housings like for example 12A1136 is installed, the bottom edge of the housing barrel should almost, but not quite, touch the top of the shaft. If there is too much space between the bottom of the housing and the shaft, then the shaft can (and will) wobble around as the cam is accelerated/decelerated by the valve springs (within the timing chain slack) and this wobble is seen as timing jitter. Machine the underside of the housing mounting flange to take up the slack.
Edited by scooperman on 17th Jul, 2012.
Alex
Member #: 1851
Woolavington, Zummerzet
I tend to use one of the rad-bracket bolts.
