Home > Help Needed / General Tech Chat > gt17 compressor stall
Custard
Member #: 8215
Rayleigh
Hey, I have just bought said turbo and am planning my engine set up.
so how well does the gt17 handle not running a dumpvalve? i know the t3 has a strong shaft and can take it.
peoples thoughts on it too please would be grand.
thanking you all.
Dave the Cake
bennyy
Member #: 9037
Doncaster, yorkshire
I wouldn't
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
No problems. In that department, but if you are to run high boost a dump valve would be on the top list of priorities
tadge44
Member #: 2500
Buckinghamshire
I,m running a GT17 at 15/16psi and even with a dump valve it squeaks and chatters at full bore changes - I guess the dump valve is not big enough.
I didn,t bother about compressor stall until I read how much damage it might cause - I do now
Carl S
Member #: 1761
Stalker
Much safer to run with a DV than without IMO.
Even with a 360 degree bearing, it still puts plenty of stress on it.
Mike-998
Member #: 9774
Buckinghamshire
Why were you considering not running one? For the price it costs surely it's not worth the risk of destroying your turbo?
Edited by Mike-998 on 16th Jul, 2012.
100% run one with a gt17...I found out the hard/expensive way. *wink*
Edited by matty on 16th Jul, 2012.
haimesyboi
Member #: 5702
Cornwall
If you want to cut down on the noise re-circulate into the intake.
Star Mag
Member #: 375
Leicestershire
I did over 30000 miles with no dump valve and a gt17 without any problems.
welshdan
Member #: 1111
s wales
I run a recirculating one with my t3. You cant really hear it unless you boot it, and then it is quite quiet
i have a really fooking big one...
i dont think it matters too much its not like we expect our turbo's to do 100k if my turbo last 5 years id be a happy bunny even if that is only 5k miles
oli79
Member #: 8480
sigged *hehe!*
Edited by oli79 on 16th Jul, 2012.
On 5th Oct, 2014 Shauna said:
The Morris Ital assassin!
Custard
Member #: 8215
Rayleigh
thanks for all the replies!
quite a mixed opinion!
it was purely because i prefer the noise.
but think I'll run one to be safe
cheers
Dave the Cake
