Home > General Chat > mpi alloy race radiators ebay chinese 42mm core
NickG
Member #: 7912
Australia oi oi oi!
so i have a direct contact with a supplier
what are the thoughts on one of these for a turbo motor.
http://www.ebay.com.au/itm/Winner-Racing-4...b#ht_1611wt_840
i can buy one delivered for 52 pounds delivered from another direct shop.
30% cooling than stock radiator
easy installation without modifitions
pressure tested and 1 year limited quality guarantee
As for high performance aluminum racing radiator, the FPI (the weld point number in 1 inch) is between 12 and 15. the core is made from the standard 4343 compound materials with the vacuum rock drill brazier whole welding formation, the tank is made from the 6061 T6 high performance aluminum material, the filler neck is made through the CNC processing , the weld of the tank and core is the manual TIG welding completely. the intensity is guarantee, the performance of rouse resistance is great.
All aluminum racing radiator with hand welded
Provide 30% more cooling than stock
Easy installation without modifications
Pressure tested and 1 year limited quality guarantee
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
sounds ok ill be doing a turbo 1098 when i get some free time so id probably look at a nice shiny rad when the time is right
It looks like the usual cheepo Chinese rads all over ebay. generally you get what you pay for
mercenary62
Member #: 9937
yeh il second that i agree with apbellamy,bet the gaurantee is worthless ,as theyll want to see the rad if it fails ,try sending it back to china at our postal rates itl cost more than its worth cheap chinese shit id say
give em hell
Ive got a chincky copy and its bob on!
It wasnt from your usual places though. It actually came from the UK.
Wintersurfer uses a cheapo Chinese side mounted rad. It seems to be performing better than my alloy Minispares version.
I think perhaps the issue may lie with quality control. They will more than likely sell a shit one that leaks along side a good one. Then its down to luck.
NickG
Member #: 7912
Australia oi oi oi!
he sent me some photos ill upload them it looks good
welshdan
Member #: 1111
s wales
I run a side mount alloy one from min-its. The rad cao had chinese writing on it. Min-its are my usual supplier, i have never had problems with the quality of thier items. The rad in question seems very efficient, my turbo motor runs super cool with this rad fitted. Im thinking of getting one of the mpi ones as per ebay for my tuned mpi. Cheers,dan
Johnny
Member #: 6926
Accrington
I would buy one to test out? Chinas products are becoming better nowadays.
hazpalmer
Member #: 9038
Carlisle, Cumbria
i was thinking of getting one, but bought a super 2 core from minispares instead
Craigie-B
Member #: 9468
Wootton Bassett
Ill be running chinese alloy side mount so will let you lot know how it gets on :)
NickG
Member #: 7912
Australia oi oi oi!
I ended up going the R1 rad instead it's bigger & fits easy with a few tank relocation mods.
Johnny
Member #: 6926
Accrington
r1 rad? can someone give me a link please?
NickG
Member #: 7912
Australia oi oi oi!
http://www.ebay.com.au/itm/R1-R-1-R-1-Yama...=item4165fb57bb
wintersurferuk
Member #: 2208
look i bought mine in thinking if it dont work i'll sell it on ebay for what i paid for it if it dont work.
mine hasn't over heated, its now 130 ish for minispaires two core.
when i bought mine is was 80+post cheeper than the other. i cant say there the same rad, its down to you to work out if its the same one ect..
im NOT telling youto buy, mine works for me, if i could, i'll buy a spaire
if i could get it from the same person ect...
edit
not knocking m/s i know there good, thats what i was looking at buying in the frist place.
ave a look, see what people are running, make your own mind up, and take a gamble.
Edited by wintersurferuk on 23rd Jul, 2012.
