| Home > Help Needed / General Tech Chat > brake size | |||||||
621 Posts Member #: 393 Post Whore Oulton Park |
17th Jul, 2012 at 08:41:05pm
how you know if your calipers are 8.4 or 7.9 and whats the diff? |
![]() 2057 Posts Member #: 9252 Post Whore Cleethorpes |
17th Jul, 2012 at 08:47:05pm
size of disk, larger piston in calper 8.4 Edited by wng691s clubby on 17th Jul, 2012. Done now needs redoing lol |
17th Jul, 2012 at 08:54:12pm
If you only have the calipers, then there's a size difference, and they do look a bit different if you have a look on google.
17th Jul, 2012 at 09:26:36pm
Simple, 7.9" brakes will have alloy 4 pot calipers
17th Jul, 2012 at 10:36:55pm
Read that wrong, didn't see you put 7.9 lol On 26th Jan, 2012 Tom Fenton said:
20th Jul, 2012 at 08:30:20am
I'm a bit confused with the hole alot i am buyin the calipers off a friend and havent got any disc, but from what i'm reading there is a size difference in the pistons, does any body no and can you notice the difference in braking really? |
20th Jul, 2012 at 08:41:19am
I've personally found pads make more difference than the small jump between disc size. From 8.4s with blackstuff pads to 7.5s and m1144 pads there was a huge braking improvement. On 26th Jan, 2012 Tom Fenton said:
20th Jul, 2012 at 08:45:46am
post a pic of the callipers and we might be able to ID them for you. On 20th Oct, 2015 Tom Fenton said:
20th Jul, 2012 at 03:46:34pm
My 7.9's don't have alloy calipers... Steel 1 pots :) I run a supercharger and I don't care the TB is on the wrong side.
20th Jul, 2012 at 07:14:30pm
On 20th Jul, 2012 gr4h4m said:
My 7.9's don't have alloy calipers... Steel 1 pots :) Lol confuse the lad even more why don't you
20th Jul, 2012 at 11:03:32pm
21st Jul, 2012 at 02:46:26pm
the dimeter across the cylinder 35mm any ideas
