| Home > General Chat > Chemical Welding / Epoxy | |||||||
20th Jul, 2012 at 08:30:56am
Does any one have any experience of the epoxy resins which claim to be on par with welding as I need to repair a bit of cast iron.
389 Posts Member #: 9751 Senior Member Derbyshire |
20th Jul, 2012 at 08:50:08am
Yes, i once tried it on a cast exhaust manifold, The place i used to work had some special chemical expoxy metal which we used to repair engine blocks in emergencies. It looked great but 30 minutes later it was like a smoke grenade has been let off under the bonnet as the metal strted to burn.
20th Jul, 2012 at 09:17:18am
Belzona, will take heat mass, but not on exhausted manifolds or turbos, onto downpipes, other than that super to get you away! Ben
20th Jul, 2012 at 09:18:39am
what do you need to fix,
![]() 2057 Posts Member #: 9252 Post Whore Cleethorpes |
20th Jul, 2012 at 09:23:35am
iv used quick steel before with good results never failed Done now needs redoing lol |
![]() 580 Posts Member #: 9580 Post Whore Surrey |
20th Jul, 2012 at 10:04:25am
Repaired lose thermostat stud hole that was weeping. stuff it in and re-tapped it. Still holding after several years. Also fixed a Landy front axle case that had a split in and my welding was shit so it dripped oil. Took the oil out and cleaned the area with brake cleaner and it stuck like shit to a blanket. Fixed the leak as well |
![]() 263 Posts Member #: 8923 Senior Member North Wales |
20th Jul, 2012 at 10:17:08am
Also used quick steel in the past with good results
![]() 641 Posts Member #: 9937 Post Whore somewhereintheuniverse near selkirk scotland |
20th Jul, 2012 at 11:30:56am
jb weld very good used it on a cracked engine block ,still in use 10 yrs later with no leaks give em hell |
