| Home > Help Needed / General Tech Chat > Engine Hoists | |||||||
![]() 883 Posts Member #: 9774 Post Whore Buckinghamshire |
23rd Jul, 2012 at 10:54:21am
Well it's almost time to try and get the new engine in the car, but first I need to get the old one out. The simplest option looks to be to lift the engine out the bay with a hoist, as the brake lines don't really need to be touched.
http://www.turbominis.co.uk/forums/index.p...tid=469104&fr=0 |
23rd Jul, 2012 at 11:00:44am
It's easy with a hoist. And as you've noted, this means no messing with brake lines either.
In the 13's at last!.. Just |
23rd Jul, 2012 at 11:07:47am
I always borrow one. Alternatively, see if anybody wants to go halfs/thirds and all share. Audi s4 b5 - 470bhp & 486ft lbs
On 15th Mar, 2012 wil_h said:
23rd Jul, 2012 at 11:46:02am
depnding on how precious you are about the paintwork in the engine bay, you and a few friends could lift it out - we used to do this all the time with some rope and a scaffold pole (probably explains why my back is knackered these days!)
23rd Jul, 2012 at 05:52:08pm
If you buy a hoist you will never get rid of it -it makes things so much easier. |
24th Jul, 2012 at 10:47:43am
That sounds a fairly good idea with the scaffold pole, especially as the engine bay is going to be painted while the engine is out, and I'm sure I can get some of the guys together to give a hand. As you said I can take the majority of the ancilleries off, so it's just a block and gearbox left to lift out, which should reduce the amount of damage I do as I lift it out http://www.turbominis.co.uk/forums/index.p...tid=469104&fr=0 |
![]() 552 Posts Member #: 300 Post Whore Cumbria |
29th Jul, 2012 at 09:06:09am
http://www.hss.com/g/67715/500kg-Engine-Crane-Folding.html
Here for the craic..
29th Jul, 2012 at 12:39:18pm
Renting might be a bit expensive if your not putting the engine back in on the same day.
