Home > Help Needed / General Tech Chat > Group A Head gasket
Noris8322
Member #: 9566
Maidstone, Kent
Does anyone know where I can get my hands on a Group A Head Gasket?
I've tried all the usual places but still having no joy. Any ideas??
Noris
Edited by Noris8322 on 23rd Jul, 2012.
bennyy
Member #: 9037
Doncaster, yorkshire
You ll be lucky, turbo Phil was the last to try, ended up having to get some sent over from a friend in Portugal IIRC
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
Noris8322
Member #: 9566
Maidstone, Kent
oh bugger! Not what I was hoping to hear
Richspec
Member #: 300
Cumbria
Speak to Phil, I think he has the entire world stock, If he will sell one it will rightly be very very expensive.
Here for the craic..
Supercharged Arden powered
Noris8322
Member #: 9566
Maidstone, Kent
Cheers, I'll have a word
ntm1275
Member #: 9395
Moss Europe are advertising them
http://www.moss-europe.co.uk/Shop/ViewProd...ateIndexID=3760
96 quid - ulp
Noris8322
Member #: 9566
Maidstone, Kent
Wicked, thanks for the heads up
I've dropped them an email, just gotta hope they have got stock. If not it looks like I might have to scrap a freshly re-built block
All is not lost, if you cannot source a group a gasket contact Mike Tanski at Ferriday Engineering and see if he can help.
I also have an engine machined for the group A gasket, I do have a spare on the shelf also and reading this I'm glad I have.
adrian
Member #: 2726
wakefield
I lost with this, can someone explain the difference please?
bennyy
Member #: 9037
The block is machined to accept the group a gasket, which has a much deeper fire ring.
adrian
Member #: 2726
wakefield
Cheers mate :)
PEP
Member #: 1145
North Wales
If ur still stuck you could always go for a cometic one-iv'e had one-very good but your gona have to have £70 spare.
No, wrong, the cometic will not have the double depth fire ring needed for the group A block.
I know you are only trying to help but please make sure you know 100% the situation before potentially having someone waste £70 on a gasket that isn't suited.
Do you think Cometic would make one to suit?
Richspec
Member #: 300
Cumbria
Phils had no luck yet in persuading the firms mentioned above to make some.
Noris8322
Member #: 9566
Maidstone, Kent
It's becoming a nightmare! Noone will reply to emails, if you ring someone they just say they will have to call u back and never do!
Anyone wanna buy a block? lol
Have you tried Ferriday Eng?
make a wire ring ,to fill the groove ,then use a normal gasket?
Mike-998
Member #: 9774
Buckinghamshire
How deep are the rings in the block? Would it be possible to get the block skimmed to eliminate them and use some short pistons? Or machine the pistons as well so their flush?
tadge44
Member #: 2500
Buckinghamshire
I think like Robert (sometimes) and I reckon a copper wire ring of the right size would do the job - and it wouldn,t cost much to find out.
Stolen from turbo-mini.com *happy*
Ferriday already do a copper fire ring for the a series. I'm not sure if that groove is just a plain parallel cut or if there is an angle to it, but if it is just a straight cut, it be tempted to dry deck it and just use the copper fire ring on its own
bennyy
Member #: 9037
Surely the block could be skimmed to accept a normal gasket? If you wanted that is.
it could. but you'd need to skim the pistons too,
Noris8322
Member #: 9566
Maidstone, Kent
Centred on each bore centre -
Fire ring recess OD in block top - 3.060"
Fire ring recess depth in block top - 0.027-0.029"
bennyy
Member #: 9037
How deep is the fire ring? Picture must look deceiving
