Home > General Chat > pattern panels
mercenary62
Member #: 9937
just received from magnum panels one rear bumper valance ,and two rear lower corner repair panels ,now in the skip ,the panels were absolutely crap they had bad creases in them and angles were all wrong for fitment ,you live and learn ,dont think itl be long b4 this company goes to the wall producing stuff like this ,so if your thinking of using pattern parts the simple reply is dont
give em hell
wng691s clubby
Member #: 9252
Cleethorpes
did you complain??
Done now needs redoing lol
I tried a few pattern panels. they where all wank!
the only half decent pattern panels i'd consider using are hadrian, and only if i cant get rover or heritage stuff
mercenary62
Member #: 9937
yeh mate lesson learnt , i did complain but was told they mustve got damaged in post ,and to take it up with the post office ,however you could tell it was badly made and not damaged in post ,just a copout from a firm that doesent care
give em hell
M-machine do the best pattern panel in my opinion. Some of their panels ive used are better than than the heritage stuff.
Forgot about mini machine stuff- it's good too
tomkidd
Member #: 1962
Lancaster
I tried a pattern wing... what a pile of crap. I offered up a genuine one and it dropped on a treat. I did however use pattern A-panels and door skins and they were fine
maccamcvey
Member #: 6673
Worral Sheffield
I have being using a mix of heratage and magnum, the ones I have being modding rear arches ect I have used magnum they are not brilliant some are much worse than others at 50% price drop over heratage what can you expect?
Magnum are the biggest pile of wank ever made!
Chalkie
Member #: 9764
Northamptonshire.
M-Machine and Herriate all ive used I do have 2 magnum valence closing panels and they fit fine when offered up
If you have never fitted Heritage door skins, then you will never know how shite others are. The differences are subtle but worth every penny of the price on the genuine skins, IMHO. That is not just me saying that but the chap thats working on mine at the moment was absolutely amazed in how well the genuine skins fitted over the non genuine
We've used at pattern front panel on a car, original wings, fitted absolutely perfectly, not a tiny bit of fettling needed!
Just welded straight up and fitted bob on first time. Nobody could believe it!
Edit:
See for yourselves...
Edited by Carlzilla on 24th Jul, 2012.
Edit:
The subtle difference in some cases is all in the weight, which is either a good or a bad thing depending on the perspective *happy*
You can tell the difference in quality of the panels material wise, theres no doubting that. I can tell the difference between my own panels yet to be fitted to my own car, and a Heritage top dash rail is thicker than the original, but still fits perfectly.
Carl S
Member #: 1761
Stalker
I also had a new front slam panel fitted (as in the picture above) which I obtained from Magnum and it seemed to fit quite well.
I plan to use herritage panels when the shell gets a refurb though, as I cant be arsed to piss about with potentially ill fitting panels. It may cost a bit more but i'm happier that the quality is of a higher standard.
