| Home > Help Needed / General Tech Chat > what trigger wheel would you recommend ? | |||||||
57 Posts Member #: 9625 Advanced Member |
25th Jul, 2012 at 12:56:49pm
hi guys so im going to go megajolt and atm i carnt go turbo :(so its for an NA engine , but i should imagine this would be one of the best places ask , what trigger wheel do you recommend ? ive seen a few , but don't really know what go for , tbh i haven't got MED sort of money so that's out the window XD any help would be appreciated |
25th Jul, 2012 at 01:01:16pm
Tom Fenton on here will do a machined bottom pulley and bracket; a fiar few of us are using them |
25th Jul, 2012 at 01:05:11pm
cheers will drop him a pm :) |
25th Jul, 2012 at 08:09:16pm
yep top bit of kit Yes i moved to the darkside |
![]() 883 Posts Member #: 9774 Post Whore Buckinghamshire |
25th Jul, 2012 at 08:18:22pm
I used this guy on ebay, he'll make it to your specifications for no extra cost, just tell him the dimensions when you buy it.
http://www.turbominis.co.uk/forums/index.p...tid=469104&fr=0 |
25th Jul, 2012 at 08:36:53pm
I'm using the specialist components one. I like the way it doesn't interfere with the damper in any way. On 7th Oct, 2010 5haneJ said:
25th Jul, 2012 at 11:04:39pm
I'd source MED kind of money to be honest. 2nd hand dampers are junk. KAD style ones that untighten themselves are junk.
Edited by Vegard on 25th Jul, 2012. On 13th Jul, 2012 Ben H said:
25th Jul, 2012 at 11:39:41pm
I don't know if it's any good but there is also this option: http://trigger-wheels.com/store/contents/en-uk/d30.html |
![]() 580 Posts Member #: 9580 Post Whore Surrey |
26th Jul, 2012 at 05:21:40am
I get very twitchy fingers on the MED site. Must............resist...........purchase............ |
![]() 27 Posts Member #: 10013 Member Hockley, Essex |
26th Jul, 2012 at 10:04:12am
On 25th Jul, 2012 jbelanger said:
I don't know if it's any good but there is also this option: http://trigger-wheels.com/store/contents/en-uk/d30.html This is the one ive used and haven't had any problems, i also used a longer Allen head bolt from minispares. |
26th Jul, 2012 at 10:16:09am
The med one is faultless imo, well worth the £210 Audi s4 b5 - 470bhp & 486ft lbs
On 15th Mar, 2012 wil_h said:
26th Jul, 2012 at 10:19:27am
I have the trigger wheels one. It does need the longer bolt though, which from them seems expensive. I just turned mine down a bit as the head of the standard bolt is a bit over engineered. http://www.twin-turbo.co.uk
26th Jul, 2012 at 10:48:05am
The thing i like about the med one is that if you have to remove and refit it will be lined up straight away i dont think this is the case with the trigger wheels one? Crystal Sound Audio said:
26th Jul, 2012 at 12:55:08pm
True, but it is easy enough to dowel or mark the trigger wheels one and the price difference is quite significant.
26th Jul, 2012 at 01:21:50pm
One advantage for the MED one is that you get a new crank damper I suppose?
