| Home > General Chat > Ignition timing | |||||||
![]() 171 Posts Member #: 9928 Advanced Member Hartley, Kent |
26th Jul, 2012 at 09:51:13am
Hi, I have a pretty much standard metro turbo setup in my mini apart from the metro turbo dizzy, all I have is the standard metro dizzy, the old man had a fiddle with my timin yesterday and got it idling abit better than it used to, but all I wanted to know is if anyone could help me out with how many degrees adv/retard I should have it set at, I'm pretty sure dad retarded it, so any advice would e much appreciated.
Low boosting for now. |
26th Jul, 2012 at 10:14:11am
I think 6deg. Btdc vac pipe disconnected Audi s4 b5 - 470bhp & 486ft lbs
On 15th Mar, 2012 wil_h said:
26th Jul, 2012 at 10:31:43am
Get megajolt :) much better than Dizzy |
26th Jul, 2012 at 11:34:26am
As Benny says good standard timing 6deg vacume disconnected. 1000 rpm
28th Jul, 2012 at 10:11:09am
Ahh excellent thanks people, will have a crack at it today!
28th Jul, 2012 at 11:12:27am
i'd have thought that a standard dizzy would have far too much cetrifugal advance for a turbo engine? On 26th Oct, 2004 TurboDave16v said:
![]() 883 Posts Member #: 9774 Post Whore Buckinghamshire |
28th Jul, 2012 at 12:37:03pm
Megajolt is pretty simple to set up, there are plenty of guide on here and on the autosportlabs website.
http://www.turbominis.co.uk/forums/index.p...tid=469104&fr=0 |
28th Jul, 2012 at 04:56:11pm
Ohh fair play! And the dizzy that I've got is just an electric metro dizzy... Seems to work fine to be honest Low boosting for now. |
28th Jul, 2012 at 07:06:44pm
Metro turbo dizzy centrifugal advance at 5000rpm is 18 to 22 degrees, Metro dizzy centrifugal advance is 24 to 28 degrees.
28th Jul, 2012 at 07:21:39pm
As above,
28th Jul, 2012 at 07:32:15pm
So ideally the best bet would be to get hold of a metro turbo dizzy? I've found a company on eBay that sells distributors for "metro turbo" I messaged him to clarify it would be okay for this set up and he said it will be fine here's a link, not sure weather to buy or not :/ http://www.ebay.co.uk/itm/MG-Metro-Turbo-E...=item19c69ebb3d Low boosting for now. |
28th Jul, 2012 at 07:38:31pm
To be honest, if you're looking at spending £80 on a dizzy, then you might as well bite the bullet and save for MJ.
28th Jul, 2012 at 07:54:43pm
yeah, ever use what you have, set it up at max rpm and accept it may be off at idle or bite the bullet and go MJ, (HE he! schamone)
28th Jul, 2012 at 08:01:28pm
Megajolt it is then! I know there's different types like tps and map?? Just wondered which would be the better bet? I'll definately make MJ my next goal in this case. Low boosting for now. |
28th Jul, 2012 at 08:05:43pm
tps for NA with hot cams, MAP for turbo and docile road engines. On 28th Aug, 2011 Kean said:
