Home > General Chat > Front mounted radiators - again.....
OK, so I know the Fiat cinq is the preffered choice.
I have one of the earlier and one of the later (no temp sender) Fiat ones to play with shortly but I started with the Metro Mk1 (brand new but non-genuine).
I've read that the Metro Mk1s come in two different thicknesses... if so I must have the thinnest and most useless.
Extended testing of the efi over the last few days and - totally stationary on my drive - at idle, the temperature exceeds 100C with the fan running continuously. Maxes at about 105-110 but the fan setting is 90 and it never stops running.
Anyone running a Mk1 Metro rad sucessfully on the road ??? - my testing has all been stationary - before I dump it for the Fiat one(s).
all the mk1 rads I have seen are about 40mm thick, the mk2 ones are about half that but still seem to cool ok, except if they have most of the fins missing like one i had....
Im going for the chinq rad for mine. works OK on johns car and I have the benefit of more holes in my valance and a bit of metal to force the air up into the rad.
also what advance you running at idle, that can make a big difference
i am using the mk1 metro rad . performance is good .no sign of overheating in any conditions .in traffic it takes about 5 to 10 minutes to get to fan initiation ,its a small homemade fan ,and usually runs for about a minute then turns off as the temp is below the switch threshold at that point .
NickG
Member #: 7912
Australia oi oi oi!
I got a R1 rad in mine it fits fine but can't say performance yet, will try update you when i have it running. :)
Make sure you get a decent Cinq rad if you do order one Rod. The cheapo one's suck!
topcat
Member #: 9408
Tiptree, Essex
I recently bought a VW Caddy one for mine, it was the biggest I could find and just fits in the front (fibreglass clubby front though), very happy with the size, hoping I won't even need much fan assistance.
www.topcatcustom.co.uk
