Home > Help Needed / General Tech Chat > mk3 rover pedal box and booster help
NickG
Member #: 7912
Australia oi oi oi!
I want to fit a tin can brake cylinder or something that will work so i have the mk1 look.
im converting to th vh44 system brake booster, will i need to buy a new pedal box or can i still use the rover pedal box?
you can swap the brake pedal over in your existing box although I recall some people have removed the actuator arm from the later pedal as another option
NickG
Member #: 7912
Australia oi oi oi!
removed the actuator arm????
On the asumption that you are running a late model mastercylinder with the integrated servo, There is an actuator arm riveted to the pedal that comes up to connect to the servo. The rod on the tin can cylinder would replace this.
If you have a tandem cylinder at the moment, you can use your current box as is
Edited by Rob Gavin on 28th Jul, 2012.
NickG
Member #: 7912
Australia oi oi oi!
can you buy them new?
NickG
Member #: 7912
Australia oi oi oi!
im sorry rob im with you lol..
right drill out the old arm & presto new one fits easy?
the hole in the pedal arm is a lot biger on the later servo pedal box.
you will also have to replace the master cylinder bracket on the crossmember with an earliear one as the hole in that is smaller lol
NickG
Member #: 7912
Australia oi oi oi!
lol lol.. ill just buy a 2nd hand one as i originally was going to do lol. works out quicker & easier. thanks lads.
It's not clear what you have already.
do you have the late servo/ pedal box assembly? or just the upright tandem master cylinder without servo?
Its the late servo/ pedal box that will give you troubles, but any earlier pedal box with any upright master cylinder will be fine with what you intend to do.
NickG
Member #: 7912
Australia oi oi oi!
Late servo pedal box. I'll just get a leyland pedal box and happy days! Easy then
