| Home > Beginners Tech > fuse rating | |||||||
![]() 2057 Posts Member #: 9252 Post Whore Cleethorpes |
29th Jul, 2012 at 02:41:39pm
how do you work out what size fuse to use? Done now needs redoing lol |
29th Jul, 2012 at 02:54:57pm
it is based on the current rating of the wire. Fuses protect the upstream wire not the down stream consumer.
http://www.twin-turbo.co.uk
29th Jul, 2012 at 03:52:23pm
well i need to fit in line fuses for all my gauges and megajolt i just dont want to start it up for the first time and it set on fire lol i wouldnt be impressed Done now needs redoing lol |
29th Jul, 2012 at 04:33:56pm
Well MJ and gauges use nothing really. If the wire you are using is 1mm sq then I would suggest a 10A fuse.
29th Jul, 2012 at 06:04:54pm
cheers Done now needs redoing lol |
29th Jul, 2012 at 06:55:35pm
I've got 3s and 5s for most circuits on my car, only stuff like the head lights and ECU etc that have bigger. On 11th Feb, 2015 robert said:
29th Jul, 2012 at 07:11:04pm
i guess the lower you go the more sensitive Done now needs redoing lol |
29th Jul, 2012 at 10:05:23pm
my wires are way over rated tbh, all i have done is switch everything on and went down the fuse box with an ammeter the fuse that went in the slot is the next one over what ever current it draws Yes i moved to the darkside |
![]() 825 Posts Member #: 9661 Post Whore Sheffield South Yorkshire GB. |
2nd Aug, 2012 at 08:49:10pm
MJ should be a 3amp fuse.. Alan. Main Build
