| Home > Help Needed / General Tech Chat > 12G295 head for 998 | |||||||
![]() 321 Posts Member #: 557 Senior Member Ireland |
26th May, 2005 at 12:39:42pm
Do you need the valves and springs when buying this head? or will the ones out of the original engine do? |
26th May, 2005 at 04:57:29pm
better with the valves and springs as the inlets i think! are slightley larger than a standard 998 head
26th May, 2005 at 10:01:34pm
The exhausts on the 12G295 are the same size as the standard 998 heads, but the inlets are much bigger.
27th May, 2005 at 08:54:26am
Inlets are VERY hard to find to be honest. I had to machine down some AEG163 35,6mm valve for my head. If the inlet valve seats are fine, you're OK, but if you need an oversize, beware. On 13th Jul, 2012 Ben H said:
