Home > Help Needed / General Tech Chat > cylinder head help
jlay
Member #: 1742
essex
Hiya i just stripped my turbo 12g940 head to start porting and opening out the chamber. Got a bonus it has had hardened exhaust seats in but on the down side all 8 seats seem to have been cut alot lower that mu other heads. they are about 1mm deeper than the casting finish of the chambers. My question is: is there any issues with this or once i grind the chamber roof to the valve height its fine. i know the spring heights wont be as they should but i can sort that and also the rocker geometry. i will try to get some pics.
Thanks James
My small bore turbo project http://www.turbominis.co.uk/forums/index.php?p=vt&tid=473901
Sir Yun
Member #: 1592
Smart Guy!
Hi, I'm working on a series of what does what on my blog..
As I expected you have to be absolutely anal retentive on valve seat geometry. I just ran some tests and i have one valve (two pairs of identical type) which is pretty much the same (seat widths within 0.05mm) just slightly different in the margin that outflows three nearly indentical other valve configurations by quite a margin around 6-8mm lift. On low lift the difference is absolutely nothing. I retested the whole lot twice because I thought I did something wrong. I messed a tiny bit with the seat in the head an managed to kill the gains i had aquired on three out of four valves
*frown* after fiddling arounf with the seats again sort of back where i started with still a few CFM missing on the new valves ..
but as what was supposed to be a simple mod an test turned into a WTF -why does this not work quest- and about 10 valve changes three seat changes and retests. So i need to try and do a decent write-up because otherwise it is just senseless graphs
that said, it will be fine with the seats a bit lower even though it might not be really optimal . Then again when you just put in more topcut you will not lose much if at all and possibly gain some mid lift
The most bang for the buck mod is doing a backcut on the valve.. 10 minutes of work. after that every bit of further gain is hard work..
Oh keep enough meat in the bowls.. I would suggest 84% for a 35.7mm valve because you can just stick in an exhaust valve to check if you are on the mark and still concentric and cutting out is much easier than adding
hope this helps a bit
Edited by Sir Yun on 31st Jul, 2012.
In short, its fine but not optimal but will work fine
m1n1man1275
Member #: 10040
Might be very handy if its going on a small bore block, you "might" not have to pocket the block!
Right where do i start!
Chalkie
Member #: 9764
Northamptonshire.
Still be best to pocket the block. also if he's using a high lift cam it be better
Sir Yun
Member #: 1592
Smart Guy!
sorry about the verbosity .. have to admire BENROSS for his economy of words *wink*
Sir Yun
Member #: 1592
Smart Guy!
Yes keep it easy! .....lol
jlay
Member #: 1742
essex
Cheers guys much appreciated advice. heres a pic anyway but dosent really show
Sir Yun
Member #: 1592
Smart Guy!
that lip does affect flow a bit, blend it out it will be fine .
jlay
Member #: 1742
essex
yeah i started chambers today. With those lips about the first 1.5mm of lift is really restricted not ideal. I know they usually have a form of machining kir but never seen them this deep. Thanks for your help james
