| Home > Help Needed / General Tech Chat > Megajolt Question. | |||||||
![]() 825 Posts Member #: 9661 Post Whore Sheffield South Yorkshire GB. |
31st Jul, 2012 at 05:14:10pm
Where do you chaps adjust your ignition timing, mines set up already but want to play around a bit with the timing, Thanks for any comments.. Alan.
Main Build
31st Jul, 2012 at 05:25:50pm
To add to above, would you do it with the software or by moving the sensor.. Alan.
Main Build
31st Jul, 2012 at 05:36:10pm
You can adjust in 5deg. Either way to compensate for the sensor being slightly out if that's what you mean. Audi s4 b5 - 470bhp & 486ft lbs
On 15th Mar, 2012 wil_h said:
31st Jul, 2012 at 05:46:03pm
Cheers Benny, is that the most you can adjust it, plus and minus 5deg.. Alan
On 31st Jul, 2012 bennyy said:
You can adjust in 5deg. Either way to compensate for the sensor being slightly out if that's what you mean. Main Build
31st Jul, 2012 at 05:49:34pm
You only adjust the sensor initially to get the basic setting. Then all other adjustment done via computer.
31st Jul, 2012 at 06:00:12pm
Yes already done that Tom, took the car for its first proper run to Crich last Sunday, got one or two miner issues that I want to sort out, not played with the megajolt at all other than, load the standard turbo map..
On 31st Jul, 2012 Tom Fenton said:
You only adjust the sensor initially to get the basic setting. Then all other adjustment done via computer. Edited by nala56 on 31st Jul, 2012. Main Build
