Home > Help Needed / General Tech Chat > MJ Hard Limiter Wiring
Mike-998
Member #: 9774
Buckinghamshire
Upgrading my MJV3 to a V4 with the new engine, and with the one i bought it came with a hard cut rev limiter.
It didnt however come with the instructions on how to fit it, and i think i'm missing a transistor.
So i have this on the Hard Limiter board:
And this on the main board:
I'm assuming i just link 3 of them together, the GND to GND, COIL to COIL_PWR + and TRIG to AL_TRIG
SO where does the +12V go? And what value transistor do i need for the Limiter board?
Thanks
t@z
Member #: 452
Chester, UK
i cant help but once you've worked it out can you post a piccy of it wired please. as i have it on mine but it dont work so wanna make sure they did it correct.
ta
www.twitter.com/lilpinkiy
evolotion
Member #: 83
Glasgow, Scotland
that transistor looks to only be required if the surface mount transistor sharing its pins isnt man-enough. I could be wrong as have know working knowledge of the mega jolt setup but thats what it looks like to me.
Denis O'Brien.
eden7842
Member #: 8852
leicestershire
Ive done it the 4th is at the other side of the board,
I think its the mj's 12v feed, just solder ur wire onto it
Edited by eden7842 on 31st Jul, 2012.
Mike-998
Member #: 9774
Buckinghamshire
cheers, just found the search bar on the autosport labs website and I think I've got it.
The big transistor isn't needed, and is only used on home built kits to make it easier. The small one attached to my board is the right one.
I'll put up a few pictures of it completed so if people find this through a search it'll be here
i fitted bennys with no instruction the 3 solder pads in your photo are clearly labled coil power, trigger and ground
the 4th is on the top side ( just off pic) and is 12v
