| Home > Help Needed / General Tech Chat > Mini won't start after rebuild | |||||||
39 Posts Member #: 10008 Member Tamworth |
31st Jul, 2012 at 08:12:30pm
Its a 998 276 cam nothing special I have a belt drive kit on it and timed it dot to dot ! But I can't get it to start it try's and splutters and dies :( any ideas and is there any way to check I haven't times it up wrong or any ideas ? Please would be great ful jay. (none turbo ) |
31st Jul, 2012 at 08:16:30pm
Have you tried swinging the dizzy to alter the ignition timing to get it to fire up? If it is trying then it is probably just that to actually get it to fire up.
31st Jul, 2012 at 08:17:11pm
Quick one here for you, recheck the firing order on the leads first! Then the ignition timing, then move on,
![]() 825 Posts Member #: 9661 Post Whore Sheffield South Yorkshire GB. |
31st Jul, 2012 at 08:22:16pm
Could it be 180% out on the timing.. Main Build
31st Jul, 2012 at 08:30:15pm
I'll have a butches Thursday night working a way all week so I'm pondering each night what can it be and can't wait to get my hand son it nd I was having to jump start it as my battery was shit from
![]() 478 Posts Member #: 9269 Senior Member Rotherham |
31st Jul, 2012 at 09:14:58pm
Wish I lived near you I would go snow boarding all the time good luck sorting your car out. Craig
1st Aug, 2012 at 12:19:45pm
Is there any y I can check can is timed correctly with out taking engine out ? |
![]() 2057 Posts Member #: 9252 Post Whore Cleethorpes |
1st Aug, 2012 at 02:36:19pm
timing light
Done now needs redoing lol |
1st Aug, 2012 at 05:10:25pm
How would a timing light prove full lift of the cam at the correct time of tdc thought timing light timed tdc to dizzy ? |
1st Aug, 2012 at 06:50:20pm
All the above comments are regarding ignition timing.
In the 13's at last!.. Just |
1st Aug, 2012 at 07:49:56pm
If you have lined up dot to dot, it should start, even of you got it one tooth out one way or the other, so don't go chasing a goose.
1st Aug, 2012 at 08:07:52pm
On 1st Aug, 2012 Minimanjay said: you didnt say you wanted to see if your cam was timed correct and as said above all other post relate to ignition timing
How would a timing light prove full lift of the cam at the correct time of tdc thought timing light timed tdc to dizzy ? Done now needs redoing lol |
1st Aug, 2012 at 08:23:49pm
Ok mate cheers :) |
3rd Aug, 2012 at 08:46:16pm
All good and done and running around gotta get used to heavy clutch from that ap racing clutth and diaghram but all good straight cut drops don't half wine !! |
388 Posts Member #: 442 Senior Member Manchester |
3rd Aug, 2012 at 09:21:45pm
So what was it? |
3rd Aug, 2012 at 09:25:32pm
Fresh batterie I then took all leads of and static timed it and put them all back on cranked it whilst loved dizzy and fired then set the tappets to correct I think I had set the valve clearances to tight which I'd imagine would cause low compression ? |
![]() 883 Posts Member #: 9774 Post Whore Buckinghamshire |
3rd Aug, 2012 at 10:28:38pm
You've got straight cut drops on a NA 998 with a 276? What was the reasoning behind it? Just the noise? http://www.turbominis.co.uk/forums/index.p...tid=469104&fr=0 |
4th Aug, 2012 at 07:30:50am
I've done head and ignition and exhaust got a well ported 12g295 with rim flow valves etc bronze guides Kent springs titanium caps ... |
4th Aug, 2012 at 08:17:22am
Ah, that makes more sense. That sounds like a nice build? Have you had it on the RR yet? What power/torque figures is it giving? http://www.turbominis.co.uk/forums/index.p...tid=469104&fr=0 |
5th Aug, 2012 at 04:35:49pm
Rolling roaded it yesterday bit lower than I expected but happy it put out 60 bhp got few things gonna do to do some improv ments :) was 60 bhp at 5050 revs :) which I don't thinks a bed rev range and on cam after 2000 got it idling at 1200 semi lumpy :) |
it's a lot of money (especially the 998 ones I think?) for no power gains, Personally I would have got the head modded or something?
