| Home > General Chat > Hdmi | |||||||
1st Aug, 2012 at 02:02:57pm
I know a few here are into there AV so a quick interconnect question, is it worth spending more money on a hdmi lead or are the budget ones fine?
Forum Mod ![]() 1927 Posts Member #: 1761 Stalker Bristol |
1st Aug, 2012 at 02:10:42pm
Cheap ones are fine. Expensive HDMI cables have been proven many times that they have very little benefit over cheap ones. |
1st Aug, 2012 at 02:14:21pm
it's all digitial, so should be no problem with cheap ones as long as you not going over 10m On 15th May, 2009 TurboDave said:
1st Aug, 2012 at 02:19:05pm
I had a cheap one on my DVD player. Quality was fine, but it failed after a couple of years. The one supplied with the TV is still spot on. On 11th Feb, 2015 robert said:
1st Aug, 2012 at 02:28:52pm
As above.
1st Aug, 2012 at 03:20:48pm
As it is digital it will either work or it won't. It does matter about lead quality with SCART leads, but that is because it is an analogue signal that can degrade but still work.
![]() 2054 Posts Member #: 452 Post Whore Chester, UK |
1st Aug, 2012 at 03:45:43pm
amazon basics FTW here :) |
1st Aug, 2012 at 03:56:44pm
we've just instructred an AV install at a clients office; recommendation from the installer was that the budget stuff would be fine as long as the distance wasn't too great - interestingly the same distance as Jimster suggested at 10m |
1st Aug, 2012 at 04:39:22pm
B&Q bargain bucket for mine :) Yes i moved to the darkside |
1st Aug, 2012 at 04:42:23pm
The reasons to buy expensive HDMI leads, beyond physical strength, have all the same credibility as those to buy an electric supercharger for £19.99 off ebay. |
1st Aug, 2012 at 05:18:32pm
yeah as above, its a digital signal so quality does not really suffer unless going long distances in which case a sheilded cable would be an idea, but even then i wouldnt expect there to be much in it. On 28th Aug, 2011 Kean said:
1st Aug, 2012 at 06:20:41pm
And making sure they have everything connected, only and issue for 3d... I run a supercharger and I don't care the TB is on the wrong side.
1st Aug, 2012 at 08:24:14pm
I use to work for a shop that sold cheap and expensive ones only difference is the price they are basic the same just expensive ones have different plastic covers quailtys no better. |
160 Posts Member #: 1085 Advanced Member Netherlands |
1st Aug, 2012 at 08:28:03pm
There are quality diferences: one DVI/HDMI cable caused my Mac Mini to display artifacts/glitches on my TV, when another (much thicker but also a lot longer) didn't. Don't spend thousands tho 1963 Cooper
![]() 725 Posts Member #: 177 Avon Park 2006 Class D Winner Woburn Sands |
9th Aug, 2012 at 11:29:53am
we use the cheap ones all the time on jobs, like Jim says ok up to 10m 16V project underway |
![]() 825 Posts Member #: 9661 Post Whore Sheffield South Yorkshire GB. |
9th Aug, 2012 at 09:11:19pm
Just Currys and the like that want sell you top price ones to make a bomb out of you, cheap one for me.. Main Build
10th Aug, 2012 at 04:07:20pm
i bought the £3 ones from toolstation and there fine Crystal Sound Audio said:
