| Home > Help Needed / General Tech Chat > Whats the weight saving from fitting aluminium door skins instead of steel? | |||||||
656 Posts Member #: 1917 AKA chargedzetec Milton Keynes |
5th Aug, 2012 at 03:02:44pm
As Title
This is FORD country, on a quiet day you can hear Vauxhalls rusting. |
5th Aug, 2012 at 03:29:16pm
5th Aug, 2012 at 03:35:49pm
cheers, ive just saved 2.25kgs from a part CFRP skin, and was wondering if I need to try a little harder?! This is FORD country, on a quiet day you can hear Vauxhalls rusting. |
5th Aug, 2012 at 05:25:38pm
Whats the weight of the complete door? I seriously doubt it! |
5th Aug, 2012 at 05:48:12pm
On 5th Aug, 2012 paul wiginton said:
Whats the weight of the complete door? This is FORD country, on a quiet day you can hear Vauxhalls rusting. |
5th Aug, 2012 at 05:52:08pm
i have been working on another pair, they weighed 17.6 and 19.2 kg both basically a full door less door cards i got them down to 10.5kg ish steel skins still, one has had welding done.. plastic windows should see them sub 10kg each easy Yes i moved to the darkside |
5th Aug, 2012 at 06:03:12pm
Complete door weight would be very interesting, mine are 4kgs each with handles, catches, Lexan and chrome trims. Steel frames and alu skins I seriously doubt it! |
5th Aug, 2012 at 06:56:14pm
I'm about to put some together for mine. I'll get them on the scales once they're together.
In the 13's at last!.. Just |
5th Aug, 2012 at 08:13:57pm
here's what ive come up with, had to do them quickly as i had 2 weeks off work and wanted to test my idea while im off
6th Aug, 2012 at 07:14:06am
a set of mk3 doors complete with card wre 19.3kg each ally skinned cut out and 4mm polycarb doors 7.5kg. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
6th Aug, 2012 at 05:40:27pm
the winder mech is 1.74kg each ( less winder handle)
Edited by Brett on 6th Aug, 2012. Yes i moved to the darkside |
7th Aug, 2012 at 01:41:01pm
Glass:
Edited by bennyy on 7th Aug, 2012. Audi s4 b5 - 470bhp & 486ft lbs
On 15th Mar, 2012 wil_h said:
7th Aug, 2012 at 02:47:21pm
That's great info, I suppose I'm going to have to unbolt the door to get a real answer to my question tbh!
7th Aug, 2012 at 02:54:45pm
Keeping it all in one thread is a good idea imo, handy for future reference Audi s4 b5 - 470bhp & 486ft lbs
![]() 27 Posts Member #: 10013 Member Hockley, Essex |
7th Aug, 2012 at 04:18:45pm
Well on another well known small car related forum they have a topic on weights which show the following standard weights.
![]() 90 Posts Member #: 9838 Advanced Member |
9th Aug, 2012 at 11:07:02am
The weights we have down for skins are:
On 7th Aug, 2012 steve w said:
Slightly off topic, but weight figures may make a really handy thread for reference? Do you mean like this one: http://www.turbominis.co.uk/forums/index.php?p=vt&tid=452099 I'd take some of those with a level of caution though. Some are obviously way off! Edited by ado15 on 9th Aug, 2012. Steve
9th Aug, 2012 at 04:34:36pm
On 9th Aug, 2012 ado15 said:
The weights we have down for skins are: Aluminium skin is 1.3Kg Steel skin is 3.6Kg (non-genuine) Steel skin (genuine) is nearly 5Kgs!!! Are these weights that you have measured and verified, or just found written down somewhere? I'm genuinely surprised that the OE steel skin weighs that much. On 17th Nov, 2014 Tom Fenton said:
13th Aug, 2012 at 04:54:43pm
The weights we have down for skins are: Aluminium skin is 1.3Kg Steel skin is 3.6Kg (non-genuine) Steel skin (genuine) is nearly 5Kgs!!! Are these weights that you have measured and verified, or just found written down somewhere? I'm genuinely surprised that the OE steel skin weighs that much. We weigh all our stock. However, to be fair, the OE skins used to come in packaged, so we might have included that. Obviously, our weights are for shipping purposes. I have just this second weighed a genuine skin without packaging and it's 4.4Kgs, so still quite a difference! Steve
