| Home > General Chat > Modifying HS SU Carbs for Boost | |||||||
318 Posts Member #: 9408 Senior Member Tiptree, Essex |
6th Aug, 2012 at 10:44:22am
Hi all,
www.topcatcustom.co.uk |
![]() 883 Posts Member #: 9774 Post Whore Buckinghamshire |
6th Aug, 2012 at 11:00:32am
I guess if you used the tee piece trick connected to the overflow pipe to pressurise the float chamber it could work?
http://www.turbominis.co.uk/forums/index.p...tid=469104&fr=0 |
6th Aug, 2012 at 11:22:21am
It's not mini based, I have a huge 1930's engine which I am going to supercharge (with an enormous nearly as old blower), and want to blow through 4 SU carbs. I just prefer the look of the HS series SU's as the side float bowls look more "period" IMO. Boost will only be a few psi, more for looks than performance! (And no I don't want to hide an injection system etc etc)
Edited by topcat on 6th Aug, 2012. www.topcatcustom.co.uk |
6th Aug, 2012 at 11:26:59am
I'm sure someone with a lot more knowledge than me will be of more use, but I don't see why it wouldn't work, so long as you seal it all like you said, then the only difference (that I can remember) is pressurising the float bowl, which sticking a take-off from the Plenum to the overflow pipe 'should' sort out? http://www.turbominis.co.uk/forums/index.p...tid=469104&fr=0 |
6th Aug, 2012 at 11:31:55am
Search for pilot tube. Sure there is something about them on here. If something is worth doing, it's worth doing half of. |
6th Aug, 2012 at 01:06:48pm
*pitot tube, just found the couple of threads, seems like a very simple solution so will probably build some into my manifold(s) for the carbs when it comes to it! www.topcatcustom.co.uk |
6th Aug, 2012 at 08:31:12pm
Is it a v8 your modding for boost?
6th Aug, 2012 at 09:11:30pm
taking the float pressure from before the intercooler may give enough pressure difference to work instead on a pilot tube/proper plenum
Yes i moved to the darkside |
6th Aug, 2012 at 09:15:31pm
Not quite, a straight 8! Engine is 4ft long, and 4 SU's will go on it a treat. I reckon I'll only be running 5psi as it's not going to be performance based and I cant risk breaking the engine as spare parts don't really exist!
