Home > Help Needed / General Tech Chat > converting from a timing belt back to chain
bill.b
Member #: 7480
Australia
I'm changing back to a chain however i wasn't the one that put the belt in, i was just wondering if anyone had any tips and tricks for the conversion and if it is worth doing with the engine in keeping in mind i would prefer not to have to take it out again.........ill be using the 'MED STEEL VERNIER DUPLEX' with the iwis chain if this assists.
Bill
bennyy
Member #: 9037
Doncaster, yorkshire
You can do it in the car no probs, just need radiator, mechanical fan and water pump pulley, and starter motor off
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
I'm assuming you'll need to time the cam in again as well
bennyy
Member #: 9037
I never, just make sure they don't move, its a bit of a game to get both sprockets lined up whilst the chain is on, but possible
bill.b
Member #: 7480
Australia
right, ill give it a go....
