| Home > Help Needed / General Tech Chat > spec ok? | |||||||
27th May, 2005 at 12:00:49am
just starting my second build from scratch and was wondering if this spec was ok basically i have the same head as sauber 36inlet 31 exhaust with 30cc chambers, i'm gonna use a grp a head gasket and 18cc pistons, question is will the cr be too low? had a chat with sauber and he was runnin the same spec but changed to 15cc pistons as it was smoother, i was also looking at getting my original turbo rebuilt to reduce the lag a little what do ya reckon before i spend too much! |
27th May, 2005 at 01:37:56am
i wudnt bother with a GP A gasket personaly.. the BK450 seems to hold up fine from what iv read* and its a bit if a wad to stomach for every time you wana whip the head off. apart from making a perfectly servicable block un-servicable for anything other than a group A gasket.
27th May, 2005 at 02:33:05am
i use a DK451 head gasket set and its been fine for me. fair enough mines only seen 10psi constantly, but on the first engine i daresay it saw about 20psi before it melted a couple of pistons.
Edited by Nick on 27th May, 2005. On 20th Oct, 2015 Tom Fenton said:
27th May, 2005 at 02:34:49am
d'oh just realised you've already got the head with 30cc chambers. ignore all that above then :) On 20th Oct, 2015 Tom Fenton said:
27th May, 2005 at 10:09:10am
Regarding the compression ratio, what sort of boost are you planning on running?? Your compression ratio will be about 7.3-1 with that spec which is good for 20+psi intercooled!!
-MINI CLUBMAN 1380 TURBO- |
27th May, 2005 at 11:44:49am
gonna try and aim for the famous 200 bhp mark but i wont run it at that for the road! although if things go well i want to buy iain's engine i'll have to wait and see. |
27th May, 2005 at 11:58:50am
Your more than welcome |
aslong as you pay the deposit im happy, i can then collect and pay from simon anyway if you cant for a while. Its my problem really, dont want to string simon out too much.
