Home > General Chat > Oil Pressure - Fuel Pump relay
Mike
Member #: 107
Sunny Sussex
if this switches off the fuel pump when oil pressure is lost, how u supposed to start the car lol
Edited by Mike on 27th May, 2005.
If you look at the wiring diagram for the std metro turbo it achieves this as standard anyway using a 5 pin changeover relay.
T%he way it gets round starting the car is that when you turn the key to "start" position it energises the fuel pump to get enough fuel pressure up in order to start the engine. The engine should then run on the fuel in the float chamber for the small amount of time until the oil pressure comes up.
that's pretty clever. I wish VWs did that, as i killed my old 16v last year by the oil pump dying..
Ben H
Member #: 184
Melton Mowbray, Pie Country
Mike,
On your megasquirt you can use the fuel pump output to acheive the same thing.
Thinking about it I'm not sure this is on the megajolt???
Ben
http://www.twin-turbo.co.uk
Mike
Member #: 107
Sunny Sussex
y the squirt can control the fuel pump, not sure if it can via oil pressure tho.
i had one of these on my car it worked well
i now run a ford cut off switch its far far neater
Mike
Member #: 107
Sunny Sussex
i'm thinking of adding an inertia switch, the engine 'could' still run after a crash with fuel still pissing everywhere.
i have about 9 sat in a box here if you want one
Mike
Member #: 107
Sunny Sussex
yes please :), paypal?? £??
Carl
Member #: 95
liverpool-on-sea
you can get inertia switchs from any csrap yard and cut off the plug with a couple of inches of wire to.*smiley*
the daddy take2
Member #: 508
27/05/2005 11:22:09 PM User | Quote
Mike, i used the standard system like this from a metro turbo, and eveytime i went round a rounderbout too fast, the pump shut down and the oil pressure light came on. it used to piss me right off having to free wheel down the road until pump came on again.
comical at first! (my dad thought it would be a good safety feature... uhhh-no!
the paint master! *surprised*D
evolotion
Member #: 83
Glasgow, Scotland
central oil pickup for you ... :)
Denis O'Brien.
I think so!
