Home > Help Needed / General Tech Chat > popping back in carb
1293 sprite
Member #: 5449
Melton Mowbray
Hi
I realise there are many causes of this problem, but what is the most common cause of the carb popping back? What are peoples experiences with this? Its freshly been built, not been set up on the rollers yet. Think I improved it by playing around with the mixture screw a bit. Does run a bit better with the choke out too which would suggest a lean mixture?
Its worse after changing up a gear, bogs down at the bottom and pops back. It does clear when the revs build up. Only reaching about 2 psi at the moment whilst running in.
Any ideas why its doing this please?
Thanks, James.
1293 88.8hp 82.2ftlb
17.3 1/4 @ 78 mph
Naturally Aspirated (for now)
Chalkie
Member #: 9764
Northamptonshire.
Sounds like the timings out if the carbs poping back. Sure its back fire that dose it
tadge44
Member #: 2500
Buckinghamshire
Sounds more like weak mixture to me.
Get it on the rollers and set up.
bennyy
Member #: 9037
Doncaster, yorkshire
Yeah sounds like its running lean at bottom end, what needle, dashpot spring? Plenty of oil in there?
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
Mega lean mixture
Lean.
1293 sprite
Member #: 5449
Melton Mowbray
Brilliant thanks, that pretty much confirms then... Not sure what needle, the carb and plenum came from iain's turbo miglia he had so thought it should be around the right mixture already as he was running 150hp on low boost. I might try and richen it up so I can get to mitp and back which will be good running in miles then get it setup shortly after!
Thanks for all your replies!
17.3 1/4 @ 78 mph
bennyy
Member #: 9037
May I be the first of many to suggest an afr gauge. Then you will be able to remove all guesswork
1293 sprite
Member #: 5449
Melton Mowbray
Yeah I've been looking at them for a while, I'll definitely be investing in the near future!
17.3 1/4 @ 78 mph
Have you got oil in the dashpot? Part throttle lean off connected properly/blanked? Hole in the gasket etc etc
1293 sprite
Member #: 5449
Melton Mowbray
Part throttle banked off, carb gaskets are new. Got 20 50 in the dashpot, a bit thick but should be ok for now!
17.3 1/4 @ 78 mph
There's no guess work here you need a rolling road set up and an aem lambda gauge......... or it will all end in tears I am afraid! Under boost
Sorry to be the bearer of. The news you don't want to here...... but all the advise above is spot on.
1293 sprite
Member #: 5449
Melton Mowbray
Pretty much sorted now! Took the dashpot off and found the needle wasn't in the damper properly. the spring bit was missing so the very badly filed needle was just dangling all over the shop. Swapped the whole top part of the carb over, set the fuel pressure at 6 psi at idle and its running lovely now! Even running cooler temp aswell! Still needs setting up but will be ok for now.
17.3 1/4 @ 78 mph
jamie@thefatgarage
Member #: 9345
Sheffield
Don't even think about running boost until you have it properly set up or you'll kill it. More of the problems I read about on here are related to poor tuning and guesswork than anything else. Spend some money and get it set up properly on a rolling road, it will save money in the end.
1293 sprite
Member #: 5449
Melton Mowbray
It is going to be set up, just got to get it mot'd first.
17.3 1/4 @ 78 mph
Craigie-B
Member #: 9468
Wootton Bassett
6 psi fuel pressure!? Shouldnt it be between 3 and 4?
