Home > Help Needed / General Tech Chat > head light rings
tonyl3
Member #: 9551
nuneaton
hi all are there different size head light rings .
madonminis
Member #: 9371
East Yorkshire
never known there to be any different ones other than maybe clubmans.
there are different rings for some of the foreign mini's such as the innocenti's, but I belive they all sit the std head lamp bowl, the repro bowls come up a bit different though, especially cheap ones.
wng691s clubby
Member #: 9252
Cleethorpes
clubman use standard headlights but no rings as the grille goes round the lights
Done now needs redoing lol
Not intentionally, but I found my minispares stainless rings didn't fit my genuine mk1 metal bowls. But they did fit onto my mk3 plastic bowls. The stainless ones were ALOT tighter to fit on than the chrome ones that came off my mk3.
would i be correct in saying there left and right handed? when i painted mine i could only get them back on i presume the side they came off
ado15
Member #: 9838
UK built Mini's all used the same rims up to 1996. Mpi's use a slightly different rim in that it didn't have the dimple on the top. The screw underneath was in a different location to clear the levelling motor.
They aren't handed.
MGB's, Frogeye Sprites, etc, used a different shaped rim that used a slightly smaller bowl IIRC. Although the actual headlight was the same size.
Steve
DSN Classics Ltd
www.dsnclassics.co.uk
